Megane II 1.4 16V Dynamique
osaaf786
Currently Drives:: Renault megane 1.4 16V Dynamique
Postby osaaf786 » Thu Sep 23, 2010 8:07 pm
I am new to this forum. I have a 2005 Megane of the above specs.
I havce recently had many problems with the engine. 1st one of the coil packs was gone and i got all 4 change. Cleaned the throttle body and still the engine is doing problems. I have taken it to various mechanics and been surfing the web and found that the engine may have a dephaser pulley problem. On ringing Renault they said that the engine in my megane does not have a dephaser pulley.
Does anyone else have the same megane with the same size engine and had similar problems??
I have been reading and people have had similar problems. But nothing really about the dephaser pulley. Can anyone please help?
Thanks in advance.
markren2004
Re: Megane II 1.4 16V Dynamique
Postby markren2004 » Fri Sep 24, 2010 12:41 pm
the dephaser pully is only on the 1.6 VVT engine
if you give some symptoms of your issues someone might be able to suggest cause.
osaaf786
Postby osaaf786 » Mon Sep 27, 2010 4:50 pm
thanks for the reply!!
Basically my car will start and i can drive it.. But whilst driving it will surge and then eventually cut out!! i have had it for a diagnostic this morning and they found nothing.after picking my car up it did the same thing and i have taken it back to the mechanic for a re-test to see if the diagnostic picks up anything.
Any ideas of what it could be??
markren2004
Postby markren2004 » Tue Sep 28, 2010 7:24 am
start with cleaning the throttle body and the butterfly inside it with carb cleaner and check the air intake tubing for any leaks / splits.
Beyond that could be a sensor, but pinpointing which one could be costly / difficult without the ECU flagging it up in a diagnostic .
osaaf786
Postby osaaf786 » Tue Sep 28, 2010 1:57 pm
Thanks for your reply.
I have just spoke to my mechanic and after doing the diagnostic again he has found there is a problem with the ECU and has said to repair the problem it will be a heavy sum. Do you know of any mechanics or do you know whether i can get the whole unit changed for a reasonable price??
harny86
Postby harny86 » Tue Sep 28, 2010 7:20 pm
HI mate i have the same problem had mine at renault today they said ites the tdc sensor (butterfly)they said 100 pound to fix av seen loads of threads on how to clean etc but i think am going to pay the 100 pound and get it done properly
Users browsing this forum: No registered users and 141 guests
