'Injection fault'
Iggypop
Currently Drives:: 04 1.9DCI
'Injection fault'
Postby Iggypop » Mon Jan 04, 2010 8:53 pm
Hello everybody,
I've got an '04 1.9 DCI. I had a problem starting it about a week or so ago, pressed the button and it didn't turn over. Tried a few more times and eventually it fired up as normal. We've had the cold spell recently and I've not used it for a few days, started it yesterday and it took a while but started after a few tries. Tried it tonight and it wouldn't turn over and I'm getting an 'Injection fault' message. I've not noticed a glow plug warning light or anything (which was my first thought) so thought I'd ask on here first before getting my hands cold and dirty.
Ray
Re: 'Injection fault'
Postby Ray » Mon Jan 04, 2010 9:38 pm
probably glowplugs
Postby davelowe » Mon Jan 04, 2010 11:06 pm
Just to elaborate, there is a thread about checking them. Very easy to do with a multimeter.
Iggypop
Postby Iggypop » Tue Jan 05, 2010 1:10 pm
I've put 4 new glow plugs in this morning, still no joy. Has anybody got a plan B?
I've checked the battery, that's holding 12v.
Postby davelowe » Tue Jan 05, 2010 2:40 pm
12V is not a charged battery. 12.2V is the absolute minimum, with 12.5V being what I would call 'charged'. If it's the original one, it might be time to replace it. Older batteries are prone to a bigger voltage drop when cranking the engine due to an increase in internal resistance (especially when cold). This can lead to spurious error messages. Check also that you are getting at least 13.5 - 14.8V with the engine running.
Iggypop
Postby Iggypop » Tue Jan 05, 2010 6:59 pm
I would suspect the battery but have tried jump starting the car, still just a bit of a click and no action. Thought maybe the starter motor was sticking so I've tried bumping it, still nothing.
Postby AlexB » Tue Jan 05, 2010 7:22 pm
When the starter engages, does it take longer than a second to fire up? I would be still suspecting the battery or the contacts. If it is the original battery, it needs to be replaced anyway.
Postby davelowe » Tue Jan 05, 2010 11:25 pm
Iggypop wrote:I would suspect the battery but have tried jump starting the car, still just a bit of a click and no action. Thought maybe the starter motor was sticking so I've tried bumping it, still nothing.
This often happens with jump leads. You need around 155 amps to start the car. Consider the crocodile clip contact area compared with a tightened corrosion free battery terminal....
Plus, if the original battery is poor, it will make the jump lead start more difficult.
AlexB offers sensible advice, and for the sake of £50, take it. Get a new battery.
Iggypop
Postby Iggypop » Wed Jan 06, 2010 7:38 am
When I press the button I just get a couple of clicks but it won't try to fire, even bumping down a big hill it didn't attempt to start. Just waiting for the RAC man to arrive.
Iggypop
Postby Iggypop » Wed Jan 06, 2010 9:33 am
Sorted, it was the battery after all that! Thanks for your help.
I've got another problem now, I'm trying to put the radio code in. I put the first digit in and press the button, get a beep but it's not moving on to the next number?
direstraits
Laguna III Ph2 Exception
Postby direstraits » Wed Jan 06, 2010 11:10 am
The procedure is simple (if you have the right code). The first symbol on the display is blinking: enter the first number, then press No. 2 on the unit (next digit of the code starts to blink) and enter the next number of the code, press No. 3 on the unit (again next digit will start blinking) and enter the next number of the code, press 4 and enter the last digit of the code, and press and hold 6 to save the code. It will work only if you have the right code. If not, go to the stealer and ask for the code of your radio.
Postby AlexB » Wed Jan 06, 2010 11:22 am
Of course it won't. First, you need to switch the "ignition" on without starting the engine. Press and hold the start button for 5 seconds while not touching the pedals. Then bump.
Iggypop wrote:When I press the button I just get a couple of clicks but it won't try to fire, even bumping down a big hill it didn't attempt to start. Just waiting for the RAC man to arrive.
Iggypop
Postby Iggypop » Wed Jan 06, 2010 3:13 pm
Bugger, wish I'd known that last night whilst trying to steer the car for a mile and a half in the dark on snowy roads with a queue of traffic behind me doing 15mph! :oops:
Will try the code again soon.
Cheers.
Users browsing this forum: Google [Bot] and 103 guests
