Window Regulator
bronkone7
Currently Drives:: 2004 Renault Megane 1600cc
Window Regulator
Postby bronkone7 » Sat Nov 08, 2008 12:23 pm
Hi All
I believe my F/N/S window regulator has gone.
1. Is there a way of checking it
2. The ones for a Megane on E. Bay don't look like mine,are Scenics the same?
Many thanks
Brian
sav0
Re: Window Regulator
Postby sav0 » Sat Nov 08, 2008 12:37 pm
take the door card off and look at your regulator you will see if the cable has broken or not.
Some of the regulators on ebay do look different to the genuine renault ones but they do work i have one in my passengers side door.
bronkone7
Postby bronkone7 » Sat Nov 08, 2008 1:36 pm
Sorry i meant checking the motor.
The cable seems fine.
Window doesn't open from either switch,have checked fuse,can't think of anything else.
Brian
DJC013
Currently Drives:: 2004 Scenic 1.9 dCi, 2001 SLK 320 Auto
Postby DJC013 » Sat Nov 08, 2008 2:08 pm
Hello Brian, i would take the whole motor/regulator assembly out of the door, then try a 12v supply from a battery and see if the motor works, that should get around any fuse/wiring faults in the vehicle. Regards Damian. :-)
2004 Scenic 1.9 dCi 120 Dynamique 6 Speed Black 17" Nervasports VF1 JMRG
Visit my Flickr site ! - http://www.flickr.com/photos/28464546@N05/
bronkone7
Postby bronkone7 » Sat Nov 08, 2008 4:21 pm
Thanks will try that.
Sorry to keep on but are the rear window regs. the same only i thought i could swap them over as we don't use the rear windows.
Many thanks again
Brian
DJC013
Postby DJC013 » Sun Nov 09, 2008 12:11 pm
Hello Brian, not 100% sure but i believe the front and rear regs are different, regards Damian. :-)
bronkone7
Postby bronkone7 » Sun Nov 09, 2008 7:53 pm
Thanks for all your help Damian....erm
What pins would i connect 12 volt battery too.
There are 6 would it be the 2 in the middle only they are fatter then the other 4 :?
Brian
Users browsing this forum: Google [Bot] and 25 guests
