BUZZING, SOZ FOR ASKING AGAIN.
toptonyb
Postby toptonyb » Thu Dec 20, 2007 10:32 pm
SORRY FOR ASKING AGAIN BUT PLEASE IS THERE ANYONE CAN ADVISE ME ON WHAT THE MOTOR IS FOR INSIDE THE REARVIEW MIRROR HOUSING, MINEIS BUZZING LIKE MAD & I WANT TO REPLACE IT.
MY 2004 DCI HAS NO CLIMATE CONTROL, SO IT CAN'T BE FOR THAT?
ANY IDEAS PLEASE?
Ray
Postby Ray » Thu Dec 20, 2007 10:47 pm
I honestly haven't heard of this problem before (other than your earlier post).
to be honest, I doubt many other people have either. I only know of the sensor for the wipers and the electrochrome *thing* is in there.
It could be that?
BurntCarcus
Currently Drives:: Grand Scenic 2008 1.9Dci (130)
Postby BurntCarcus » Fri Dec 21, 2007 9:18 am
Does your mirror have a tiny hole in it facing the window? Its an Electrochrome mirror if it does like mine. Sounds like the motor is screwed up for some reason, you should never hear it. Try putting your finger over the hole then shinning a torch at it, it should turn a blue tint.
silencer51
Postby silencer51 » Fri Dec 21, 2007 10:19 am
Ray wrote:I honestly haven't heard of this problem before (other than your earlier post).
It could be that?
On the contrary, my experience indicates that its a common problem across the Renault range (esp. the Laguna II)
Inside the rearview mirror housing is a small motor/sensor combo.
When the ignition is on, the motor operates sucking in air for the sensor to analyze (temperature and humidity conditions inside the cabin) so that the A/C unit can perform its job properly.
Of course a moving part is always prone to failure. :(
Some people have had success shutting it up by removing it and blasting the unit with pressurized air, thereby cleaning it...
Keep in mind that the buzzing you hear could also be caused by a flaky rearview mirror housing cover that rattles as the motor inside operates - try this: while you hear the buzzing try pressing the plastics of the rear view mirror assembly, if the noise changes then thats the problem...
Gray Megane II 1,6 5dr hatch 05/2003
Set dephasers to stall!
toptonyb
Postby toptonyb » Fri Dec 21, 2007 8:55 pm
thank you guys for your help, the motor is inside the mirror housing not the mirror its-self, if i slide down the cover attached to the windscreen under the mirror the motor is in there, it is about 1" long, 2 wires coming from it & has 2 screw securing it in place, it has a tiny gap allway around it & i can see the fins inside revolving, if i insert a very tiny screwdriver to stop the fins moving the buzzing stops? i am sure the motor has seen out its days i am just trying to find out what it is for? even renault say its for climate control, but giving themmy reg etc they say my car has no climate control & does not have this motor fitted???? i was looking at the motor with my own eyes as the parts dept told me this??? doh'
hey thanks again, any more info appreciated.
Postby AlexB » Fri Dec 21, 2007 11:30 pm
It is not supposed to be their without the climate control system. Is it possible tha the car was rebuilt and parts came from different donors?
If the cabin computer does not support climate, then you can try disconnecting this motor. Can you see the connector?
All I can say is based on the docs pointed at in my message in Links section.
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 88 guests
