Dephaser and coil packs - replacements any better?
GoldenWonder
Postby GoldenWonder » Wed Oct 31, 2007 1:14 pm
My 2005/55 1.6 with 18k has already had the dephaser pulley replaced but not the coil packs (yet - surely just a matter of time!)
Question is, does anyone know if the replacements are any better? My dephaser lasted 12k, so can I expect a similar life out of the newer one? Ditto the coils when they inevitably pack in.
Also, when the dephaser is changed, do Renault change the cambelt? If so does this count towards the mileage before they belt is changed again, i.e offset by the mileage already on the car? Just curious as I will hit 50k in the car in less than 18 months
redcbr600fs
Postby redcbr600fs » Thu Nov 01, 2007 5:08 pm
Yes is the answer to both according to my local dealer... I recently had my dephaser replaced, and it was 10k miles short from my cambelt change so asked... And they said there was a mandate from renault instructs them to change cambelt when and if dephaser is changed... Mine was in again yesterday though, for a injection computer reset, when i asked why this was needed, i was told it should have been done after dephaser as standard....
Mégane (52) 1.6 16vvt Dynamique, Sport Hatch, Black, Comfort pack.17" Alloys
Masta_Inc
Postby Masta_Inc » Sat Dec 01, 2007 7:37 pm
I just had the depahser replaced and the mechanice told me that the new ones have been modified and are wider and hence will not have the same problems.
I will not be happy if it goes again in 12,000 miles as it cost me £700 for this. He also said in such instances there's a chance your water pump could need replacing. Mine didn't luckily.
Are the coils and dephaser connected? One coil went at exactly the same time as the dephaser. It still juts a little at start-up, and lacks a bit of its old power, is this normal or is it the kind of part that requires time to be driven in?
GoldenWonder
Postby GoldenWonder » Sun Dec 02, 2007 4:21 pm
I don't think they're linked by anything other than the fact they don't last more than 10k miles. :cry:
I asked the question about the dephasers to our local Renault garage the last time I was in and the technical 'expert' became very evasive about how many failed units were themselves replacements, so I'm guessing the newer ones aren't much better!
Masta_Inc
Postby Masta_Inc » Sun Dec 09, 2007 4:42 pm
Well about two weeks after I've had the dephaser done, it's started cutting out again... unbelievable.
Any ideas?
walibe
Postby walibe » Sun Dec 09, 2007 7:18 pm
If it is the dephaser again theres no way they fitted the new corrected part. Other parts that cause the same symptons include those coils and the camshaft sensor also causes identical issues.
Masta_Inc
Postby Masta_Inc » Wed Dec 12, 2007 12:50 pm
Well you were right, it's a cam sensor.
Quoted £185 to fit which I thought was a bit steep no?
He's giving me a discount and charging £115.
I wasn't expecting it to be this much since the part is around £30!
Unless it's the unbelievably unjustifiable charge for diagnostics...
TheFinn
Postby TheFinn » Wed Dec 12, 2007 4:46 pm
If this announcement by Valeo is anything to go by, the new replacement coil packs from 2007 on' should last twice as long as the old ones... Provided of course you do get the new '245104' reference and not one of the old stock.
petesafc
Postby petesafc » Wed Dec 12, 2007 6:58 pm
£185 to supply and fit a camshaft sensor!? That's daylight robbery! Needed to change same on my 1.6 vvt could only get part from renault (£29)but its dead easy to change, one 10mm bolt and thats it half an hour tops including a cup of coffee!
walibe
Postby walibe » Wed Dec 12, 2007 8:47 pm
I was charged £120 for the camshaft sensor change on my Megane. If I had known it was that easy to change I'd have done it myself!
weebobt23282
Postby weebobt23282 » Fri Jan 18, 2008 11:34 pm
hello i had this problem from ma car with ony 5434 miles on the clock and only just had it fixed 2 days ago part was replacesd under warranty, if you say it only has a 12k life span then why are these cars not getting recalled or something like that. car now has 12500 miles on it
Megane 1.6 V V T sport saloon (55)
snowy
Postby snowy » Sat Jan 19, 2008 10:33 pm
is 30 euros a good price for them?
Users browsing this forum: No registered users and 57 guests
