Convert Electric Windows to Manual?
freddymercurystwin
Postby freddymercurystwin » Fri Mar 09, 2012 8:22 pm
Anyone ever done this? My drivers side has packed up again and as I expect to keep the car until it dies (joy) I'm not sure I have the will to be faffing about with unreliable windows so am considering converting it to manual. I couldn't care less about it being electric frankly I only open the damn thing about once a month! Do some Meganes even have manual windows?Assuming they do I don't see why getting the gear from a breakers and swapping it over should be too painful! Any thoughts anyone?
morganjake1544
Re: Convert Electric Windows to Manual?
Postby morganjake1544 » Fri Mar 09, 2012 8:33 pm
I'm sure that even the entry level models (Extreme and Authentique) had electric windows in the UK. The Authentique being the 5 door had manual wind ups in the rear but they're different size and shape to the front. So what sounds like a straightforward job may be tricky as the parts might not exist and you could be a pioneer in this area!
freddymercurystwin
Postby freddymercurystwin » Fri Mar 09, 2012 8:51 pm
Well if no Meganes even have winders at the front then the plan is a no goer! :(
Postby joeishmather » Sat Mar 10, 2012 7:34 pm
Why dont you move the window regulator/motor to the unaided part of the door?
This is what I did to mine-
Not sure how clear it is from those photos but I've basically bolted it in place where no water can get! :-)
Users browsing this forum: Google [Bot] and 27 guests
