lowering help
Discussions around the Mégane 225.
c12mgf
Currently Drives:: megane 225 renaultsport
lowering help
Postby c12mgf » Thu Sep 15, 2011 12:45 pm
finding it hard to find a spring kit or a coilover kit i cam afford?
any help is welcome
Re: lowering help
Postby joeishmather » Thu Sep 15, 2011 3:35 pm
What can you afford??lol
c12mgf
Re: lowering help
Postby c12mgf » Thu Sep 15, 2011 6:28 pm
looking at a few hundred
Re: lowering help
Postby joeishmather » Thu Sep 15, 2011 6:48 pm
Get some fk lowering springs for around £140 I have them on mine.. But if your wanting to spend a bit more, sure you could get a set of coilovers.. Which are ultimately better than just changing the springs..
Matty_225
Currently Drives:: Megane 225 LUX
Re: lowering help
Postby Matty_225 » Thu Sep 22, 2011 8:48 pm
A bit more than £140, the cheapest set of coilovers for the 225 are £1100+ KW Variant 3.
Ive got a set of Cobra 40mm on mine with 3 coils cut from the rear so now its 60mm on the rear. The ride is excellent and feels firm.
Re: lowering help
Postby joeishmather » Thu Sep 22, 2011 9:08 pm
https://www.fk-automotive.org.uk/websale ... 2%2fmd5%7d
There the fk springs, 57€ +p&p... As far as I'm aware they fit any megane 02> :cool:
Re: lowering help
Postby joeishmather » Thu Sep 22, 2011 9:10 pm
As far as coilovers go here are 2 ive just found..
https://www.lkperformance.co.uk/coilover ... rId=208305
That's a cobra set for the 225 at £615
And vmax for bit over £500
https://www.modworld.co.uk/renault-megan ... 9423-p.asp
c12mgf
Re: lowering help
Postby c12mgf » Sat Sep 24, 2011 12:23 pm
and will all these fit the 225?
dont see it listed on the adds
c12mgf
Re: lowering help
Postby c12mgf » Sat Sep 24, 2011 12:40 pm
Matty_225
Re: lowering help
Postby Matty_225 » Mon Sep 26, 2011 6:47 pm
Make it easy for ya, Only K-Tec can supply coilovers for the megane 225, heres a link for ya.............
http://www.k-tecracing.com/show_product.asp?id=2008&appid=12
These are the cheapest for the Meg 225. K-tec have most contracts tied up with parts for the 225. For example, You cant buy the 2.75'' Exhaust system direct from milltek, you have to go through K-tec to buy it.
Re: lowering help
Postby davelowe » Mon Sep 26, 2011 8:31 pm
Matty_225 wrote:Ive got a set of Cobra 40mm on mine with 3 coils cut from the rear so now its 60mm on the rear. The ride is excellent and feels firm.
Are you serious?! Genuine question...
I'm thinking to myself: get the spring compressors out of the toolbox, put the springs in a vice (uncompressed obviously) and take an angle grinder to them. Is that (in principle) what you've done?
c12mgf
Re: lowering help
Postby c12mgf » Tue Sep 27, 2011 9:51 am
yeah coilovers are a tad on the rich side, maybe next year as just bought new alloys.
might look at springs then. but cutting them is bit on the dangerous side is it not?
Re: lowering help
Postby joeishmather » Tue Sep 27, 2011 10:41 am
I think if your daft enough to do this then cutting compressed springs while on the car is pribably the way to go!lol
:conf
And I think it's widely unacceptable and dangerous to cur coils from your springs! Each to their own tho...
Re: lowering help
Postby davelowe » Tue Sep 27, 2011 9:19 pm
:conf
That's what I thought - so I calculated what the result would be using FEA and it wasn't pretty!
c12mgf
Re: lowering help
Postby c12mgf » Wed Sep 28, 2011 6:58 pm
going for springs this week
will a 30mm drop be enough with set of 18`s???
Return to “Megane 225”
