center console lights not working
Any questions you may have before you buy or receive your car can go in here!!
morephun
Currently Drives:: 02 megane 2 dynamique
Postby morephun » Thu Dec 12, 2013 9:09 am
hi guys, just about to pick up a megane 2 on a 52 plate today, so hopefully will be on here a lot more. The centre console lights are not working, all other interior lights work apart from radio aircon ect.. any ideas where to start? which fuse to check? thanks
all of this bit...
morephun
Re: center console lights not working
Postby morephun » Fri Dec 13, 2013 9:20 am
Is there any other forums I can ask on? This one seems a bit errm dead lol
Postby Stranger » Fri Dec 13, 2013 9:44 am
Give it time, people have lives other than the net.
To be going on with have you looked at the FAQ section and also the sticky thread containing the manuals in the problems section? To save you a few seconds I've copied and pasted the link below which will take you directly to the manuals sticky:
viewtopic.php?f=2&t=12790
Postby AlexB » Tue Dec 17, 2013 10:05 am
Yes, the fuses are in the above link. Here is the link to the actual document to read
https://ray-lee.co.uk/megane/dialogys/MR364MEGANE8.pdf
There are 2 fuse boxes, one in the glove compartment, and the other under the bonnet. You might need the first one.
Don't be surprised if you find out that the problem is caused by somebody fiddling with electrics when installing/removing the radio.
jt1996
Currently Drives:: Renault Megane 1.5 dci 2004
Postby jt1996 » Thu May 19, 2016 5:25 pm
Hello,
New to the forum and I have experienced the same issue, trying to find the fuse number for the center console lights.
I have a 2004 1.5dci. If anyone could help that would be great?
Jamie.
lamdask
Postby lamdask » Mon May 23, 2016 10:46 pm
I just bought a 2003 Megane and it had a unlit center console.
Following the youtube guide below I changed two bulbs behind the fan and temperature control and had light back in the center console.
https://www.youtube.com/watch?v=L5Zv72l ... XrfKek_Abg
Regards.
Mikael.
'03 Megane II 1.6 16v.
