ABS switch
michaelaj
ABS switch
Postby michaelaj » Mon Jul 02, 2007 2:51 pm
what do u think of a switch to turn off the abs
TheFinn
Postby TheFinn » Mon Jul 02, 2007 7:47 pm
TBH I have to say that would be potentially very dangerous: first of all the ABS system is solely responsible for acting as a pressure regulator for the rear brakes as there is no separate load-sensitive limiting valve for the rar brakes on these cars anymore.
So if the ABS was to be be deactivated, the braking pressure to the rear wheels would no longer be regulated and you could end up with dangerously rear-biased brakes. With the possible (and likely) consequence of the car spinning instantly the moment youd be slamming the brakes any harder (in a panic stop for example)! :cry:
michaelaj
Postby michaelaj » Thu Jul 05, 2007 11:11 am
the abs will help u on emergncy stops but limits what u can do with the car... the switch can be turned on and off i was wondering if it would cause any trouble with the cars electric systems
MrAsia
Postby MrAsia » Thu Jul 05, 2007 12:08 pm
How does it limit what you can do with the car?
Remapped Mégane 1.6L
michaelaj
Postby michaelaj » Fri Jul 13, 2007 4:12 pm
i tried the car on track once with the abs still on as soon as i would try to use the brakes to skid into a turn it would stop the car........but i tried the switch and almost destroyed my car so im gonna take ur adivce and leave it alone
