Boost Gauge on 1.9 DCi
- Currently Drives:: Megane 120 DCi Dynamique
Hi, where do people normally fit boost gauges in Megane's? Ive always wanted to have one for novelty more than anything.
I dont want to drill anything or remove anything really if possible. Where do you route the pipe from engine bay into the compartment?
Looking at a 52mm version of one
Megane II 5dr 1.9 DCi 120 Dynamique in Yellow (yes yellow like the renaultsports) - Now Sold
- anth_dci
- Currently Drives:: Megane II DCi 120 Dynamique 52 plate
Re: Boost Gauge on 1.9 DCi
i would also be interested in fitting one of these, but ive no idea where to start
- Currently Drives:: Kia Cee'd 1.6 CRDi
I fitted one.
see the front quarter panel. you'll be able to thread the pipe along there to the inside of the car.
07 Kia Cee'd 1.6 CRDi
Remapped
Remapped
i'll take pics n show u, 'even tho ive no megane the description will still be the same'
Remapped
Remapped
Brilliant thanks for that, ill wait for the pic as im still not too sure.
Yeah just thinking of a 15 PSI max one - 52mm
No idea what it would boost to as standard but imagine the 15 would be ok?
Ahh thanks for that, ill look for ones up to 30 psi then
Just got to figure out what you mean to get it through lol
Does a 120 DCi really boost to 22psi as standard? would of thought it was less for some reason
Any ideas where to mount the pod where i wouldnt have to drill or anything. was thing in the corner of the windscreen near the A pillar just stuck down with some double sided tape or something
i'll get the phots up over the weekend as im in work atm.
Remapped
Remapped
- dalefletcher111
1 bar wouldn't be enough if it boosts to 22psi.
1 bar = 14.5psi
I don't know anything about boost pressures but given 1 bar is normal air pressure I though it'd be higher than 22psi.
1 bar = 14.5psi
2004 1.9dci 120 dynamique 3dr
Standard Subaru's Boost to about 22psi, when a bit of work has been done to them get boost to about 2-2.5 BAR
Remapped
Remapped
i had one on my old 306, the novelty wore off in about a week
