Sony CDX-GT30 RN
wi11
Sony CDX-GT30 RN
Postby wi11 » Fri Oct 23, 2009 10:12 am
Just bought a Sony CDX-GT30 RN, i was told this would work with any megane II stalk and display.
It doesn't appear to work! The CD, radio works fine but the stalk and display don't, I have connected the Black, White and yellow connectors but nothing!
I have a 53 dynamic megane II does anyone have any ideas?
Thanks, Will
A13XDT
Re: Sony CDX-GT30 RN
Postby A13XDT » Fri Oct 23, 2009 1:21 pm
This should work. Does every pin on both connectors have a corresponding pin on the other?
Alex
wi11
Postby wi11 » Fri Oct 23, 2009 3:30 pm
Thanks for the reply, yes the back of the radio has all the pins, the yellow plug has 5 wires to it but space for six, is this usual?
dsyggy
Currently Drives:: megane 1.6 vvt and scenic 1.9dci
Postby dsyggy » Sat Nov 21, 2009 2:49 pm
The GT30rn only works with the update list 2006 onwards. It is the wiring inside the car that is the determining factor. Like me you will have to purchase a sony with a pre-out and cd changer plug and then the connects2 adapter to keep the display and stalk working. This info is not made clear anywhere as you have found out.
thanks
