Hi all. I;ve got me a double din headunit. All electrically installed, but looks shocking at the moment! I've got a 2004 megane CC and have removed the CD player and in-dash changer (Both for sale if anyone interested). I've purchased this http://www.incarexpress.co.uk/view_product.php?partno=CT23RT02A and it will give me the cradle to hold the HU. It wont cover all the gap left though. My old stereo fitted flush. Do I need to also purchase this http://www.incarexpress.co.uk/view_product.php?partno=CT24RT06 to cover the gaps around the edge?
I know there's an excellent post about the brilliant Kenwood double din unit but i thought that only required the bit I've bought. Any help very much appreciated.
Jason
Double Din install
- Currently Drives:: 2004 Megane Cabriolet 1.9 dCi
2004 Grand Scenic 1.9dCi - Location: Suffolk
- Currently Drives:: Proton 1.6 Lxi Wira
Re: Double Din install
PM sent, from another Jason!!
What you need is the 'connects 2' CT23RT02.
Heres there PDF
http://www.connects2.com/pdfdocs/articles/dd-kits-low.pdf
It states its for a 06-07 megane but i used it to fit my double din and it was a fantastic job.
You can see it here..
Heres there PDF
Thanks. Did that include the plastic surround and double din cage? I bought the CT23RT02A from which the cage fits, but fascia is too narrow to cover the gaps.
Yea was all that was needed in one box.
• Cage
• Surround
• Brackets to hold it in place.
• Large bits of foam... that I am yet to find a use for.
The cage wouldn’t be in the correct position if the surround didn't fit. I had to put the surround in position first, then the cage went ‘though’ and clipped to it. I then was able to prize down the metal tabs to secure it.
Finally slotted in the radio...
• Cage
• Surround
From a post i made a few months back...
I couple wanted to see a double din in stall.
When the original head unit and multi changer / cubby hole are removed there is a cross bar (plastic strip) that needs to be removed by a hack saw or plastic heat cutter, and then filed.
To the rear of the craves created one needs to cut away the top protruding plastic oval ( this is used to hold the original HU in place.) has to be removed to allow attachment of GPS aerial in my case. ( See pic 4 )
Here you can see the cut away plastic and the spliced hand brake wire, to allow use on the move.
I have used the Connects2.com double din cage. On the website it states it's for the Meagne 2008, but the dash has not changed through 2002 - 2008 and in fact once delivered is labelled 2005 - 2007.
Nice post mate, I plan to get a double din into my meg somewhere down the line
Has anyone every come across the eonon ones on ebay?
are they just cheap tat or are they any good?
Adam
Adam
bull20 wrote:Nice post mate, I plan to get a double din into my meg somewhere down the line
Adam
You get what you pay for lad... There cheep for a reason... Components/GUI (Graphical User Interface) is pish poor.
Your better to save a bit longer and buy a pioneer/alpine etc.
From experience i can tell you if you buy cheep from eBay you will disappointed.
Bad times
lol must see if I can get my hands on a 2nd hand one then
