freelanderuk wrote:Hi and welcome to the forum,
any questions you have post in the relative section and you should receive some reply's also use the search function as that will bring up loads of information
Hi and thank you. I have only just been able to reply as this is the first time I have been able to get on the lap top in a few days, for some reason I can read the forum but can't comment on it via my phone, (Samsung S4), keeps coming up with 'SQL error' what ever that is.
Anyways, I've looked through the problem section and followed the route of a loose conection under the seat, had a look at her car but found the connections were fine but then I thought about checking the connectors on the clutch switch and found that someone had cut the wires. I think what someone had done was to cut and join the wires together to be able to start the car without pressing the clutch or brake, god knows why. Anyway, recoconnected to the switch and all is fine now.
I've only driven the car twice now but it seems a very comfortable car and for a small engine it seems perfectly adequate for what she needs it for. she seems happy enough with it and is getting used to how diesels drive after having driven petrol cars only since the 1990s.
I was very impressed when I put £30 worth of diesel in and although it was only at half a tank the range showed 448 miles. Can't even get that out of my 2.2 petrol Vectra on a full tank, lol. Sadly I'm unable to stretch to a new car just yet but when I can it'll have to be a diesel now me thinks.
