Tuning box fitting and test
jim1.9dci
Currently Drives:: 53 1.9dci
Postby jim1.9dci » Fri Mar 13, 2009 9:43 am
ordered a tuning box for my 1.9dci 120 yesterday afternoon from colin at tdtuning for the discount price of £120 and it arrived 8am this morning :cool: so here is a few pics of where to plug it in and where i mounted it (probably not the best place but its pretty secure) , im off to try it out now and see what its like..
downsyndromedhorse
Currently Drives:: 3DR Black 1.9dci Megane 04 Plate 120 BHP
Re: Tuning box fitting and test
Postby downsyndromedhorse » Sat Mar 14, 2009 9:26 am
How did it go?
I've got some money set aside which i'm thinking of spending on one of these.
If its not perfect i might just sace a few more pennies and get a full remap with a performance exhaust.
jim1.9dci
Postby jim1.9dci » Sun Mar 15, 2009 4:45 am
done about 150 miles with it now and its good, does a few more miles per gallon definately, and overtaking is easier you can feel the extra torque , not as big a gain as expected but still worth it, no downsides at all , no smoke or juddering or any warning lights all good so far :-) would like to get dyno to see the real gain
pw981
Postby pw981 » Sun Mar 15, 2009 12:00 pm
2004 Megane II 1.9dCi
jim1.9dci
Postby jim1.9dci » Sun Mar 15, 2009 7:58 pm
why would the turbo blow?
pw981
Postby pw981 » Mon Mar 16, 2009 1:14 am
from what I've heard, ECU remaps alter turbo boost pressures as well as other parameters (hence bigger power/torque hikes), where as tuning boxes just alter the amount of fuel going in to combustion.
tdtuning
Currently Drives:: Renault Megane II 1.5 DCi
Postby tdtuning » Mon Mar 23, 2009 3:24 pm
well I have done 20,000 mile with a remap and a further 2000 with a box fitted turned up higher than we recommend and I have not blew my turbo. The box works as follows
The power comes from the fuel. If you increase the rail pressure the car will inject the fuel with higher pressure. Every engine can have more power than the manufacturer activates. The electronic unit activates it . When the fuel is pushed in at a higher pressure the ECU gets new sensor readings and alters boost etc accordingly.
Jim thanks for the Pics they look great do you mind if I steal them or use them even. Would love to find out the results if you do get it rolliing roaded as well.
mattj85
Currently Drives:: Renault Megane II 1.9 DCi Privledge
Postby mattj85 » Wed Apr 15, 2009 6:39 pm
How comes you only paid £120.00 when their website quotes £299.99
Renault Megane 1.9 dCi (88 kW / 120 PS) 11.02 -
Standard 88 (120)
Optimised 105 (143)
Would love one but aint getting one for £300 !! Can get a remap for that !!
jim1.9dci
Postby jim1.9dci » Sun Apr 19, 2009 6:56 pm
yeah no prob td use pics, the price was discount for forum members and i think they are about 150 normally
Poddy
Currently Drives:: Kia Cee'd 1.6 CRDi
Postby Poddy » Mon Apr 20, 2009 1:57 am
the main reason why the turbos blow in the 1.9 dci is because when they get serviced who ever does the service doesnt change the filter for the turbo, which clogs up and then no oil gets to the turbo causing it to blow, most diesel turbos can handle pressures up to 20psi when i had my megane i had a boost gauge fitted to it and had cranked the boost up to 22psi, stuck it well never had a problem with it.
07 Kia Cee'd 1.6 CRDi
Remapped
downsyndromedhorse
Postby downsyndromedhorse » Mon Apr 20, 2009 12:05 pm
Whats the pressure on the turbo as standard?
Poddy
Postby Poddy » Mon Apr 20, 2009 8:08 pm
i think its about 16-17 psi im not sure as i didnt have a boost gauge on the car untill after i fitted a boost controller
Remapped
tdtuning
Postby tdtuning » Thu Aug 06, 2009 11:06 am
mattj85 wrote:How comes you only paid £120.00 when their website quotes £299.99
Standard 88 (120)
Optimised 105 (143)
Hi sorry not been on the site for a while, the £299 Box is an aluminium cased box exactly the same function just in a better housing.... the £150 unit (now £179.00) does exactly the same but obvisouly in just a platic housing, we are now offering multi-channel boxes as well however these are alot more expensive at around £389.00 they plug into not just the rail sensor but rail and boost, and there are a few more boxes which of 3, 4 or 5 channel applications for certain vehicles. The plastic 1 channel boxes are still available at a discount price now £130 but i will give you free delivery as well.
I can offer discounts on the aluminium boxes as well if your after any other type of box.
Thanks www.tdperformance.co.uk
spungal69
Postby spungal69 » Tue Sep 29, 2009 8:33 pm
Poddy wrote:the main reason why the turbos blow in the 1.9 dci is because when they get serviced who ever does the service doesnt change the filter for the turbo, which clogs up and then no oil gets to the turbo causing it to blow, most diesel turbos can handle pressures up to 20psi when i had my megane i had
Where is the filter for the turbo? Do you mean the engine oil filter??
direstraits
Laguna III Ph2 Exception
Postby direstraits » Tue Sep 29, 2009 9:09 pm
Mathematics are as follows: more power=more heat. The cooling system on your car is optimized for the power you get as standard. Any increase in power means much higher increase in heat (ICE is a heat engine), and there is no way for the heat to escape from the system. Valves, pumps, turbine are the parts that suffer the most.
