front springs twisting with noise
JCE EVO
Currently Drives:: evo 9 & renault megane 15 dci
Postby JCE EVO » Sun Mar 01, 2009 3:46 pm
hello lads i am new to this forum ( i am a member of the evo based forum the MLR) . i have a problem with my other car a 2004 megane 15 dci , i am getting a strange nosie from the front springs when i turn the steering as if they are twisting also abit of a knocking sound when i hit a bump . hope some one can help cheers . johnny
markren2004
Re: front springs twisting with noise
Postby markren2004 » Mon Mar 02, 2009 10:51 am
noise over a bump would normally be ball joints or suspension bushes.
if its a "twang" noise and only at low speed corners (or turning wheel when stopped) then likey to be the top suspension mounts - common on the megane.
lucydci
Currently Drives:: Megane II 1.5 dci Dymanique Sport Hatch
Postby lucydci » Mon Mar 02, 2009 10:34 pm
Agree, sounds like top strut mounts, does it do it at car parking speeds, ie quite slow with a lot of quick steering movements? If you get someone to rock the steering wheel whilst you hold onto the front spring you will feel them jumping as the top mount sticks and cause some resitance then when it does move it does so sharply causing the srping to jump in its mounting.
2004 Black Megane II 1.5 dci Dynamique Sport Hatch
