power supply needed
nickbell69
Currently Drives:: megane 1.9dci priv 53
power supply needed
Postby nickbell69 » Sat Jan 10, 2009 4:47 pm
I'm fitting a Harmon Kardon plug and play for i pod use and rather than use the cigarette socket for power i'd rather permanently connect it with leads supplied.
Got 3 leads
yellow +12v dc
red - acc
black- gnd
Need help as to what to connect these in line with.
Can they go to wires from stereo? If so which ones would be of help?
Hope someone can help.
Nick.
Andy_CC
Currently Drives:: Megane CC and Nissan Navara Avantura
Re: power supply needed
Postby Andy_CC » Sat Jan 10, 2009 6:58 pm
nickbell69 wrote:I'm fitting a Harmon Kardon plug and play for i pod use and rather than use the cigarette socket for power i'd rather permanently connect it with leads supplied.
Got 3 leads
yellow +12v dc
red - acc
black- gnd
Nick.
connect them to the back of you radio matey.
look on this online manual of the radio wiring, looking at the left hand side menu scroll down to section 86A - Radio then click on RADIO "entry" level connections. this will bring up the wring for the radio. click here for manual https://ray-lee.co.uk/MR364MEGANE8.pdf
The black connector at the back of your radio
The yellow wire u want to connect to 4 battery supply
The Red wire u need to connect to 7 accessories supply
The Black wire u need to connect to 8 Earth
nickbell69
Postby nickbell69 » Sun Jan 11, 2009 1:46 pm
Cheers for that Andy, most helpful.
That file also had details on removing CD changer too which would of been next question. :D
Andy_CC
Postby Andy_CC » Sun Jan 11, 2009 7:13 pm
nickbell69 wrote:Cheers for that Andy, most helpful.
no probs matey, 2 birds with one stone............ :lol: let us know how you get on fitting it and how it performs etc.. as im on about getting one on them for my Navara.
cheers Andy
nickbell69
Postby nickbell69 » Sun Jan 11, 2009 11:03 pm
Will do. Tried it first just to check it worked and it seemed ok. i've mounted the control just above the handbrake and display is top right just above glove box(easier to hide cables i thought and slightly less visible to prying eyes).
Unit is in glove box so just need to wire up power now, job for next weekend i think. I'll "try" and post pics once done.
