Door handle Cracking
- Currently Drives:: 2004 Megane dynamique 1.9dci 120
Anyone got a problem with the cap next to the door handle cracking? How do you change these things guys. I am new to the board and just want some helpful advice. Cheers
Work in progress, new megane facelift alloys, kenwood ice install. Ipod connection
- Chambo211
- Currently Drives:: Renault Megane 1.6 vvt Oasis Black
Re: Door handle Cracking
I had this problem on my old Megane.I just took it to my local dealer and they replaced the cracked ones with new ones.They didn't cost anything as it was still under warranty but I can't see it being expensive if you did have to purchase them.
Renault Megane, Oasis, Black, 1.6, 16v, vvt, Panoramic Roof
this is one of the common "cosmetic" issues with the megane..along with the badly fading of the black triangle trim just ahead of the front doors. some people had them replaced under warranty...but there will be a lot of 3+ year old cars with these issues now.
What do you reckon Renault would charge for the caps if the guy on ebay sells the loy for £1.20?
john1980 wrote:What do you reckon Renault would charge for the caps if the guy on ebay sells the loy for £1.20?
Probably somewhere in the region of 10 sheets each...they aren’t called the stealers for no reason!
- Chambo211
Surely you could fit them yourself? Maybe you could get the cracked ones off with something (careful not to wreck 'em though!) and slot the new ones on?
- Currently Drives:: Megane 1.5dci 53 Plate
I bought some replacement end caps off fleabay cost around £10 for 4, the rear doors are a pain in the arse to change but once you have done one the other is easier
so how do you do it?
if you open the drivers door you will notice a hole with a rubber stopper in it, remove that.
Then get a metal coat hanger or something similar and make a small hook on the end.
Now look inside the hole you will see a metal leaver use your hook to hook it and pull towards you, the end cap will then pull out, remember to put the leaver back when you have replaced the end cap to hold it in place, this is the same process for the front passengers door too
The rear doors are similar but you have to do a bit more fishing to get hold of the leaver
