Air bag warning light apears then disapears
kenboy
Currently Drives:: Megane automatic
Postby kenboy » Sun Dec 07, 2008 11:13 am
Just had the the Megane Serviced at a Renault Dealer 35000 service I have noticed since then the warning light for air bags lights up then go's out after a while
I have worked out that it seems to be some how connected to when I move the seats I have spoken to the dealer they say that they would have to put it on a clip test to find the problem another 75 quid to tell me that there is a problem with the air bags system that ( I ALREADY KNOW ) any advice !! :banghead :banghead :banghead :banghead
Ray
Re: Air bag warning light apears then disapears
Postby Ray » Sun Dec 07, 2008 4:13 pm
do a search on the forum.
your dealer should fit something to the airbag loom under your seat. or it might be slightly disconnected in which case connect it back tightly.
nickbell69
Currently Drives:: megane 1.9dci priv 53
Postby nickbell69 » Sun Dec 07, 2008 11:00 pm
As Ray says check the connector under the seat, they come loose easily when seat is moved and just need tightening.
Mine does it regular if i hoover car or when the better half drives and the seat gets moved.
kenboy
Postby kenboy » Fri Dec 12, 2008 10:49 am
HI
Thanks for the information on seat loom I will try and locate it this weekend and fix (Thats if the wife doesn't take the car to work) what am I looking for some sort of plug!!! :oops:
