Front Wiper Hitting Pillar
TobyS
Currently Drives:: Megane 1.5 Oasis (3 door, 6 spd gears, panoramic sun roof) 55 plate
Postby TobyS » Fri Nov 14, 2008 1:12 am
The front wiper on mine overshoots and hits the pillar. Can it be adjusted easily without taking it to a garage?
Jonault
Re: Front Wiper Hitting Pillar
Postby Jonault » Sat Nov 15, 2008 8:39 pm
I suspose you could see if the wiper arm can be pulled off and repositioned on the splined mounting pin.
benking
Currently Drives:: Ford puma
Postby benking » Sat Nov 15, 2008 8:46 pm
If its the same as any other car take the cap off the bottom of the wiper where it is fixed, undo the bolt and reposition. Real easy. If this doesnt work maybe something is worn or broke i.e. the mechanism or threads. Which should be easy enough without taking to a garage. just need patience as on most cars removing the plastic trim hiding the mechanism in quite fidly to remove
