Ive had a quick look at found that the window at the top should fit under the rubber seal obviously so it seals!! but it doesnt, it sits slightly on the outside of this seal so it is leaving a gap between window and seal. If you slam the door really hard or push down on the door as u close it, the window will pop under the seal as it should!! the passager side door and window shuts and seals perfectly.
has anyone else had this problem, if so is there an easy fix for it before i spend half the day at the dealers trying to get them to sort it under warrenty!!
Thanks in advance
Andy
