if things coulnt get any worse for me, as most people know i posted a topic up about engine mount, now today the bloody car is leaking water in the passenger door pocket but its only a bit of water, cant cant seem to see where its coming from,
another thing ive just got in the car and the drivers door handle seems tight to open as if its stiff, and the same when opening it from inside the car it feels like its getting stuck anybody got any ideals?
water leak and door handle problem
- Currently Drives:: megane 1.5 expression dci
Re: water leak and door handle problem
sorted the door handle i just sprayed WD40 and its done that, its just the door pocket now i read on here that they have drainage holes where are these?
- Stranger
- Currently Drives:: BMW X1
Drainage holes afaik are along the bottom of the doors, also check around the speaker housing and the actual door seal itself.
My brother has started getting water in his passenger door pocket. It just appears to be excess condensation.
2003 Megane II 1.6vvt Dynamique Hatch
IanH wrote:My brother has started getting water in his passenger door pocket. It just appears to be excess condensation.
sounds like thats what ive got, it went to the garage today to get checked over they done a water test and no leaks the amount of water i found does look like condensation, so im not worries
- Currently Drives:: 2005 Renault Megane 1.4 16V Expression
According to peeps, this is a common fault. I've sorted the leak on my 05 Megane II. I fitted a door skin between the door and the plastic door trim and i silicon'd the gaps on the back of the plastic door trim (especially behind the door pockets) as water was coming in at the corner of the door pocket. I used talc power to find the source of the leak.
Job sorted.
Job sorted.
i had same problem on my megane 05 took back to dealers they said it was a common problem water comes in through wing mirror
Users browsing this forum: No registered users and 86 guests
