minimum brake disc thickness??
bobbyb1288
Currently Drives:: 2005 Megane Tourer 1.5 dci
Postby bobbyb1288 » Fri Oct 24, 2008 8:30 pm
Hi Y'all
Does anyone know what the new and minimum rear brake disc thickness is for the 2005 1.5dci Sports Tourer?
If it's got pistons or breasts it's going to be expensive!
DJC013
Currently Drives:: 2004 Scenic 1.9 dCi, 2001 SLK 320 Auto
Re: minimum brake disc thickness??
Postby DJC013 » Sat Oct 25, 2008 5:05 pm
Hello, in my Haynes manual for my 2004 Scenic 1.9 dCi, they quote New discs at 8.0mm and Minimum thickness at 6.5mm, hope this helps, regards Damian. :-)
bobbyb1288
Postby bobbyb1288 » Sun Oct 26, 2008 9:37 pm
Many thanks but the disc appears to be greater than 8mm originally.
DJC013
Postby DJC013 » Wed Oct 29, 2008 8:31 am
bobbyb1288 wrote:Many thanks but the disc appears to be greater than 8mm originally.
Sorry about that, may be different for a Meg, regards Damian. :-)
A13XDT
Postby A13XDT » Wed Oct 29, 2008 12:00 pm
https://www.renault.co.uk/Resources/PDF/ ... ins_UK.pdf
2nd page of the pdf has got the car, brake disc diameter and thickness.
Alex
bobbyb1288
Postby bobbyb1288 » Wed Oct 29, 2008 8:45 pm
Cheers Alex, just what I'm looking for. Bought the car from a dealer who sold me the car with rear discs at 8.15mm. They're going to replace them or I won't be happy. Will keep you posted if you're interested. Rob.
bobbyb1288
Postby bobbyb1288 » Mon Nov 03, 2008 8:17 pm
They are 270mm diameter which means their minimum thickness is 9mm.
mldd0
Postby mldd0 » Mon Mar 15, 2010 7:46 pm
i have a 53 plate megane 1.6 16v looking at changing me rear disks and bearing would disks measuring 270mm x 10mm fit me car? there from a sports tourer 1.5dci on a 05 plate
pw981
Postby pw981 » Mon Mar 15, 2010 8:29 pm
from memory, all Megane II saloon and hatch have 240mm rear discs, the sport tourers and scenics have larger rear discs.
2004 Megane II 1.9dCi
bobbyb1288
Postby bobbyb1288 » Mon Mar 15, 2010 9:16 pm
Sports Tourer has 270mm Diameter disc rotors, yours has 240mm so they wont fit. Might be possible to swap the calipers over assuming bolt mounting pitch is the same.
Users browsing this forum: Bing [Bot] and 74 guests
