Any ideas?
almeganesport
Currently Drives:: Megane 225
Any ideas?
Postby almeganesport » Fri Oct 10, 2008 6:33 am
My 225 pulls to the left, pretty severe when braking! Apparently the garage i bought it from is fixing it. Also the engine has big vibration during idle but again this is getting fixed when the part arrives. Since coming back from the garage, when i take my foot off the accelerator while driving, a strange grinding noise comes from the car, i can especially feel it through the clutch pedel. If i push the clutch in it stops! I'm assuming its a clutch problem.
Can anyone help with any ideas on this? The garage gave me the 225 back m while they wait for the parts but i'm concerned its doing damage driving it.
Re: Any ideas?
Postby wanda » Fri Oct 10, 2008 11:28 am
Maybe it needs wheel alignment. Most garages check and only charge if it needs adjustment. still should be under £25.
andywills
Re: Any ideas?
Postby andywills » Fri Oct 10, 2008 12:48 pm
sounds like it could be a clutch or gearbox problem?
terry_mccann
Re: Any ideas?
Postby terry_mccann » Fri Oct 10, 2008 1:05 pm
Why should a car pull to one side when gearbox or clutch are faulty? Dont think so....my bet is that it has either got to do with a stuck brake piston or, more likely, worn out steering components, presumably on the side the car pulls to when breaking.
Busy_Man
Currently Drives:: 1.8 Zafira Life Auto
Re: Any ideas?
Postby Busy_Man » Fri Oct 10, 2008 1:08 pm
I think Andy was refering to the grinding when not under throttle and this going when fully costing with clutch disengaged.
04 Plate 1.6 Dynamique
Issues to Date:
Dephaser - replaced
Cam Sensor - replaced
Start up problems, goes to two cylinders unless reved to hell - annoying, but untraced cause.
Water Leak in Boot - removed, came back, removed, came back again. Given up
