How To: Check & Change Glow Plugs
FAQ and Tips and tricks relating to various problems.
dry_flood
Postby dry_flood » Sun Aug 24, 2008 7:56 pm
If you ever get the "check Injection" message on screen then this is the first thing to do before taking the car to a garage.
Do this while the engine is fully warmed up, it will make it easier to remove the glow plugs if you need to change one. It is advisable to wear gloves as obviously the engine is hot
Tools Required:
10mm Deep Thin Socket
Socket Extension Bar
WD40
Multimeter
Time required:
10 minutes to check all 4 glow plugs
5 - 10 minutes to change 1 glow plug
Lift The bonnet
Undo the two 10mm bolts at the top of battery cover. The bolts need to be fully removed but be careful as the clip on nuts underneath can fall off into the engine bay. The battery cover flicks over to the left.
Turn your Multimeter to 20 Volts and place the probes on the corresponding battery terminals. I.e. red probe to red terminal, black probe to black terminal.
You are doing this to check the voltage of your battery.
My battery is currently showing 12.67 Volts. Write down the voltage your battery is showing.
The engine cover is held down by 3 push clips underneath. To remove it you just hold onto it and lift.
The yellow circles below show the position of the glow plugs.
The glow plugs are covered with a black plastic connector with a wire going into them.
Holding the black plastic connector (do not hold the wire) gently pull the connector off the glow plug
Now get the red probe from your multimeter and place on the red battery terminal. Hold the black probe on the top of the glow plug.
Check the voltage displayed on the multimeter. It should be exactly the same or very near to the voltage you wrote down earlier. If it is more than 2-3 volts lower then it could be on its way out and It would make sense to change it now while you already have everything dismantled.
Mine was showing 0.00 volts so was definatley dead.
Get your 10mm deep thin socket and extension bar. Place it on the glow plug and turn anti clockwise.
warning: Do not try and force it to turn.
If it will not turn then give it a squirt of WD40 and leave it for 5 mins. Keep giving it little turns and a squirt until it is easier to turn. Eventually it will come out.
Below is the glow plug I removed
You can purchase glow plugs from any good motor factor. My replacement cost £11. You can buy them cheaper online but I couldnt be bothered to wait.
Insert the new glow plug into the hole. Carfully screw it in by hand. Do not cross thread it!!!! It is very costly to have rectified. Once it is finger tight, use the socket to nip it up. Do not over tighten it, again this can cause problems.
Check the voltage of the new glow plug in exactly the same way as you tested the old one. My new glow plug is showing the same voltage as my battery. Yours should too.
Reconnect the black plastic connector, you will feel it click
Double check that you have reconnected all of the connectors and have removed all your tools from the engine bay.
Start your car. If the "Check Injection" message is still showing then disconnect the battery and leave for 15 mins. This will reset your ECU Make sure you have your radio code first
In most cases it will not be necesary to disconnect the battery but sometimes the ECU will store the error code and display it everytime you start the car.
Replace the engine & battery covers.
Now all you have to do is pat yourself on the back and think about the money you have just saved. :beer
Gaz
DJC013
Currently Drives:: 2004 Scenic 1.9 dCi, 2001 SLK 320 Auto
Re: How To: Check & Change Glow Plugs
Postby DJC013 » Mon Aug 25, 2008 10:13 am
Great post ! And the pictures help a lot , regards Damian. :-)
Toosh
Currently Drives:: 03 Megane 1.9 dCi 120 Dynamique Sport Hatch in Black.
Panoramic Roof, and loads more stuff.
Postby Toosh » Mon Aug 25, 2008 11:55 am
Brilliant post flood :cool:
Will remember this thread when mine pack in, which they will :-(
andywills
Postby andywills » Mon Aug 25, 2008 3:43 pm
it's posts like this that should be locked onto the top of the forum, good work :-)
WebCode
Postby WebCode » Mon Aug 25, 2008 4:56 pm
Yes a Good post, but let me add another way of testing the plugs ..
Remove the glow plug connectors. Set the meter to Ohms. Put one probe on any convenient point on the cylinder head and the other on the glow plug centre.. If the Impedance (resistance) is any more than 2.5ohms then the plug is on the way out.
Remove it and replace..
99% of defective plugs will be "open circuit" so will show NO resistance at all.. It is rare that these high current plugs "partially" fail..
Also check that the factor gives you the correct voltage plugs.. There are some 6 volt ones that look the same, but they will burnout as soon as you turn the ignition on.. The voltage is stamped on the body of the plug.. Either 6v or 11/12v
dry_flood
Postby dry_flood » Mon Aug 25, 2008 5:41 pm
your all welcome. Now if only someone could shed some light on my latest issue http://www.meganeownersclub.co.uk/forum/viewtopic.php?f=2&t=6951&start=60
Gaz
terry_mccann
Postby terry_mccann » Mon Aug 25, 2008 6:48 pm
Great howto...cheers mate....
Postby AlexB » Mon Aug 25, 2008 9:53 pm
For glow plug checking/removal/installation instructions see p.295 in MR364MEGANE1.PDF (French):
https://www.reno.ro/index.php?s=e7cc151c ... 1627461167
The most important bit there is the torque value, which should be 15 N*m. When removing a glow plug, do not apply more than 2x of this figure -- cancel the job if they are seized! Apply some anti-seize paste to the thread of the new plugs.
I also remember, that I chose a 1/4 inch extension bar for easier access (1.9dci F9Q-800 engine).
For my engine the following plug is OEM:
Beru
0 100 226 373
GN 018
11V
(GSF reference was R18822)
Ray
Postby Ray » Fri Nov 14, 2008 6:17 pm
stickied by request
jamie.osborne
Currently Drives:: Megane II 1.9 DCi Privalige
Postby jamie.osborne » Sun Nov 23, 2008 12:57 pm
Does anybody know if a "how to" has been done for the 1.9DCi (circa 2005) ? I need to replace the glow plugs and there is a plastic cover over the injection pipes and the heater plug location which "appears" to be held in place, after removing all fixings, by an inlet pipe. Unless there is some trick, it seems that this inlet mechanism might need to be dismantled, but I hope I am wrong.
Here's hoping
Jamie
busternlouie
Postby busternlouie » Sun Nov 23, 2008 2:52 pm
Use the table below to identify your engine:
Where "X" is "B" = 5dr "C" = 3dr
Now check the code in the top corner to see which air duct guide to use.
This one...
or this one...
Now use this guide to change the glow plugs:
jamie.osborne
Postby jamie.osborne » Sun Nov 23, 2008 8:02 pm
Thanks busternlouie, it is as I thought. Your post and the rest of this thread have been extremely helpful.
Many Thanks
Jamie
wabybaby
Currently Drives:: 2003 Megane 1.9 dci Dynamique
Postby wabybaby » Sat Nov 29, 2008 9:51 pm
Hi
Great post I followed it and it was nice and simple to do thanks to your pics. Does anyone know what causes the glow plugs to go in the first place? Had my car about 2 months and replaced a full set on purchase and then a single one this weekend... Just wondered if I may have a fault somewhere else down the line causing these to go so often..
busternlouie
Postby busternlouie » Mon Dec 01, 2008 5:33 pm
wabybaby wrote:Hi
All glow plugs have a limited life span and will eventually burn out, much like the element in fan ovens. However they should last longer than two months. Its possible that the plug changed over the weekend was faulty, or maybe the heater plug relay is stuck causing the plugs to be on all the time. You need to check if you are still getting a 12volt supply at the plugs a fair while after the light has gone off the dash.
ootmatree
Currently Drives:: MEGANE 1.5DCI
Postby ootmatree » Tue Jan 27, 2009 1:37 pm
Brilliant post mate. I have recently cleaned my egr on my megane1.5dci '04 plate, but I still have the lack of power problem when the car reaches 50mph any ideas? I've heard it may well be the high pressure diesel pump disintegrating.....not worth thinking about. cheers
clarky
Return to “FAQ / Tips & Tricks”
