Is this a problem or is it normal ?
tronky
Currently Drives:: 2005 Megane II 1.6 L with Koni Adjustable Shocks
Postby tronky » Sun Jul 20, 2008 12:51 pm
Hi
It happened that I was running around 100KM in a left turn on the left lane and there was part of the lane that was wet & I had to brake
the ABS didn't fire and the car felt as if it was skiing over the wet surface & it was pulling to the right aggresively with the same skiing feeling.
Normally ( on dry surfaces I mean ) the ABS will fire if it's required to.
Last time I checked was last Thursday at Renault Agency & not at a dealer's .
Everything was fine except that the suspension needed some tightening.
The car is an 2005 1.6 Sedan with Auto Transmission and with Koni Adjustables, 205/60 R15 with Steel wheels.
Was that a normal action ? a possible one ? or does it indicate a fault ??
Users browsing this forum: Bing [Bot] and 46 guests
