Hi
Has anyone had issues with their Megane2 cutting out whilst driving?
Mine did and the AA came out and found water in fuse box under the bonnet.
I took the car to a Renault dealer, they said I needed a new fuse box after running a diagnostic check. They cleaned the fuse box, and I booked the car in for a replacement to be fixed and then I went home with the car. 3 hours later the AA where towing me back to the dealer.
2 days later my car is fixed and my pocket has lost £330, but fantastic to have the car back.
6 hours later, same problem occured!! so I am a real happy chappy, if Renault cannot fix the issue who can! in the meantime I have an extremely unreliable car.
Has anyone had a similiar issue? and if so can you tell me how you fixed it.
Up to this week I have loved the car, now I am having concerns, any help would be appreciated.
NB: My car is a 03 plate, 1.9dci dynamic, I have owned it for 4 years and have done over 70000 miles and up to now it has been a joy to own.
Cheers Si
Well I have been at Renault for 2 hours this morning, they have checked the car over, cleaned connections etc and found nothing wrong. I was told by the service manager to run it for a couple of days and let him know and that there was no charge today, hey things are looking up.
After driving for 10 miles it cut out again, now booked in for tomorrow the 4th visit to Renault. I do not hold much hope that Renault can fix it! so any ideas please let me know.
Cheers Si
Megane cuts out whilst driving! help please!!
Re: Megane cuts out whilst driving! help please!!
Do you get any error messages displayed on the screen?
Hi
I have had the following messages:
Electronic fault.
Injection fault.
It failed at renault today and they could not figure it out. The car goes back tomorrow but I do not have much confidence that they can fix it.
Any ideas?
Cheers Si
Electronic fault.
Injection fault.
Any ideas?
Cheers Si
- Currently Drives:: renault megane 1.9dci dynamique(02)
hi, mine has been doing the same, mostly on idle and go to pull away!! checked electrical connections and solved it, for now at least!!
michael.linsey wrote:hi, mine has been doing the same, mostly on idle and go to pull away!! checked electrical connections and solved it, for now at least!!
Hi, thanks for the reply. Renault had the car for 3 hours yesterday and checked connections etc. Got home same problem, the car is back with the dealer now for its 4th visit!
I hope its an easy fix and I hope your repair lasts. Cheers si
Sib - What sort of speeds does yours cut out at? I have a similar problem with mine (225 Sport) cutting out at speed. Its got its 4th visit to Renault this Friday.
mustdash wrote:Sib - What sort of speeds does yours cut out at? I have a similar problem with mine (225 Sport) cutting out at speed. Its got its 4th visit to Renault this Friday.
Well mine has cut out at 80 miles per hour and standing at the lights!
Anyway Renault have now fixed it, I got the car back yesterday, apparently a wire from the fuse box to the injection system has corroded! only cost a further £280 to fix. The service manaager at Camden motors Dunstable said you should expect this of a car this age an milage.
Looks to me that Renault only build their cas to last 5 years and no more than 85000 miles!
I will be writing to Renault but the stories I have heard about their customer care I feel doubtful.
Oh after spending £630 at Renault the outside temperature is -39 degrees and my air bag warning light keeps coming on, however I do not fancy going back, as I can not afford it anymore!
What do they charge if you have a mechanical problem!!
Good luck with yours.
Sib - see my post about my problems! Hopefully mine is sorted now! there was a bit of rubber glove in the fuel tank (that was replaced a couple of years ago) that was getting sucked up and blocking the fuel into the engine!
Hi many thanks, I will take a look, Cheers
Users browsing this forum: Bing [Bot] and 95 guests
