radio problem
dci120matt
Currently Drives:: 2001 Peugeot 306 GTI-6 ohh yesss
1988 renault 5 1.7 GTX
radio problem
Postby dci120matt » Mon Jun 23, 2008 7:10 pm
i had to disconnect the battery yesterday and so obviously the power was lost to the radio and sowhen i put everything back together the radio came up with code, so i put the code in and nothing happens, i have pressed every button after putting it in but nothing, it should be the correct code as it was in the owners manual with the key numbers and other things, its doing my head in as its a 20 mile round trip to my girlfriends and i have no tunes to listen 2.
cheers matt
sav0
Currently Drives:: Megane 1.5dci 53 Plate
Re: radio problem
Postby sav0 » Mon Jun 23, 2008 7:52 pm
you should enter the code then keep your finger on 6 it should put up incorrect code if the code is wrong.... and I think you can only enter the incorrect code a number of times.
renier
Re: radio problem
Postby renier » Mon Jun 23, 2008 8:50 pm
No, you can enter the code incorrectly as many times as you want, only the waiting time will increase significantly with each incorrect entry :)
You can also confirm the code once you have entered it by holding the lower button on the steering wheel controls until you hear the beep
Users browsing this forum: No registered users and 185 guests
