oil leak!!!!!
dci120matt
Currently Drives:: 2001 Peugeot 306 GTI-6 ohh yesss
1988 renault 5 1.7 GTX
oil leak!!!!!
Postby dci120matt » Mon Jun 23, 2008 7:03 pm
hi everybody, when i changed my boost control solenoid yesterday i noticed that i have an oil leak. if you take the engine cover off there is a black pipe going over the engine and at the top there is a circular thing which connects the pipes, firstly what is the circular thing for? and the leak is coming from the pipe going to the rear of the engine where it meets the circular thingy i will put a cable tie or jubilee clip over it as it was quite loose, has anybody else had this problem and what did you do to sort it?
cheers matt
Re: oil leak!!!!!
Postby AlexB » Mon Jun 23, 2008 9:09 pm
Positive Crankcase Ventilation (PCV) system. Most likely nothing serious, just a loose pipe. Still make sure that the system is not blocked. Otherwise it will blow the seals or cause excessive oil consumption. These pipes and the positive pressure valve (the round black thing) should be replaced from time to time.
Read the manual (in Links) for details.
dci120matt
Re: oil leak!!!!!
Postby dci120matt » Wed Jun 25, 2008 8:43 pm
ok thanks matey.
Re: oil leak!!!!!
Postby AlexB » Thu Jun 26, 2008 12:04 am
:cool:
terry_mccann
Re: oil leak!!!!!
Postby terry_mccann » Thu Jun 26, 2008 6:10 am
I guess it is this you mean....I have the same effect and on my car it looks like that now:
Users browsing this forum: No registered users and 203 guests
