Fusion ET-AT 110 Sub
Bigfish
Postby Bigfish » Sun Jun 08, 2008 7:34 pm
Hi guys,
I have just been given the above ear bleeding equipment Unfortunatly no instructions or more to the point no wiring diagram.
The most of it lok pretty easy aprrt form getting through the bulkhead. One wire I havnt got a clue about is blue and goes into the power plug along with two reds and a two blacks on the amp /Sub. I have been told that the blue wire is the switched live has anyone got one of these or can point me in the direction of the wiring diagram. I am not keen on popping the amp or turning my wheels into a mobile B-B-Q. Any help would be apprecaited
Thanks //Bigfish//
//BIGfish//
Mattj
Currently Drives:: Renault Megane 1.9 DCi
Re: Fusion ET-AT 110 Sub
Postby Mattj » Thu Jun 12, 2008 9:13 am
Right run a main power cable from the battery into the positive on the amp - obv run it thru a fuse near the battery!!
Take an earth cable (bigger diameter) than the power - (less resistance so easier to earth if short circuit) and connect to an earth point near the amp and then connect to the negative terminal
Off of your headunit you should have a ACC wire (basically an ignition wire) if not use the yellow ignition wire. Basically this is used to automatically switch the amp on and off when the ignition is live.
Then connect the speaker cable to the sub from the amp
AWAY YOU GO - NO HEARING LEFT :rock
Renault Megane II - 1.9 dCI
Bigfish
Postby Bigfish » Sun Jun 15, 2008 6:41 am
Mattj,
Thanks for your help with the wiring , all is set up and working just fine my ears contiue to bleed with the racket.
//Bigfsh// 8)
//BIGfish//
Mattj
Postby Mattj » Mon Jun 16, 2008 11:12 pm
got my whole car rattling now - think i have gotta take mine to renault to sort out sunroof sounds like it bout to collapse with the bass !!
