Hi
After getting the broken spring replaced last week I have tried to start the car today and it wont start with the clutch depressed. It starts fine with the brake depressed though. (If I keep getting little problems like this then it's going, only had it 3 months).
Anyway, has anyone any ideas what it could be? I've seen other stories about a wire coming loose from the clutch etc.
Thanks in advance.
Car won't start from clutch!!!
Re: Car won't start from clutch!!!
Found out the problem. The wire has come away from the connector on the pedal. Looks like a DIY job to be honest but I might take it to the garage.
- Ray
it is a DIY job. Renault only extend it by a few inches to stop it happening again (AFAIK)
- Currently Drives:: 2005 megane CC in black 1.6vvti, not long had it but so far so good,
mine has never started from clutch but stick your head under the steering coloum all it is is a simple 2wires into a switch, my wires have snapped from the switch but join the wires together and you wont need to depress the clutch or the brake the curcuit is complete and the car will just start when you press the start button
- Currently Drives:: Renault Megane 1.9 DCi
yeh but if you join the wires together - you cut off the only safety mechanism - and thus the car can start in gear which will not only endanger others if accedentaly pressed but also keep the starter engaged as car will keep tryin to restart as thinks that because the clutch is down - that the gearbox wont matter
Also when i tried it kept having "electric fault" come up on the dashboard
Renault Megane II - 1.9 dCI
I think I'll just get it repaired !! I'd do it myself but the wire has snapped from right inside the connector.
Users browsing this forum: No registered users and 150 guests
