Heya,
Got a question: I've been reading in older topics about a guide for gettting the AMP cable through the firewall, where can I find that tutorial? Since it might come in handy.
Thanks!
Erik
Tutorial for guiding AMP wiring?
- Erik Olijnsma
- Currently Drives:: Renault Mégane II GT 2.0 16V LPG Privilege Luxe
2004 Renault Mégane GrandTour 2.0 16v (something) Luxe LPG & 1988 Renault 5 GTTurbo
- Ray
Re: Tutorial for guiding AMP wiring?
do a search for meganesport in the ICE section. it's hosted on there.
- Erik Olijnsma
I found it, but the link is dead
hi, i fitted an amp in the boot using the spare tyre well, managed to thread the wire through the passenger side, i removed the glovebox and this gave access to the carpet area, i found a rubber bung leading to the engine bay, cut a hole in the bung and thread the wire through, after a lot of carefull fishing with a wire hook i managed to pull the wire through and bolt it direct (fused) to the battery + terminal, i then replaced the bung so thewire would not rub and short on the body. just be carefull that the wire you thread through is kept away from hot items and moving items.
hope this helps
simon
hope this helps
simon
- Erik Olijnsma
Thank's, but don't forget I drive a LHD car
I guess I have to look behind my pedals in that case, or find a way around and go through the wall behind my glovebox.
Bytheway, I just installed my Kenwood and it looks quite fugly, there is a big gap between panel and radio, are there any spacers available?
Yes, you will need one of these, will fill up the gap nicely:
https://www.carmedia.nl/catalog/product_ ... en-renault
when fitted, it looks like this:
- Erik Olijnsma
Thanks, is there also one for the bottom DIN-gap?
