16cm speakers in MegII doors
Erik Olijnsma
Currently Drives:: Renault Mégane II GT 2.0 16V LPG Privilege Luxe
Postby Erik Olijnsma » Fri May 23, 2008 6:57 am
Hello,
From saturday the 31st of may I will be the proud owner of a '04 GT 2.016v Privilege Luxe. It came very nice and I love it.
But, I know I am going to be unhappy with the OEM Ice, so the headunit goes away for a Kenwood XXV-01D with a addition for the steeringwheel remote control and display output.
Speakers however....I read that they are 13cm in the doors, and I am not happy with that. I had a very nice 16cm Hertz compo in my Meg I coupe, and I am going to fit them in the Meg II.
Anybody done this before? if yes, got any tips and tricks?
Would appreciate help and suggestions. It can save me a heck lot of time... ;-)
Thanks in advance.
Erik
2004 Renault Mégane GrandTour 2.0 16v (something) Luxe LPG & 1988 Renault 5 GTTurbo
renier
Re: 16cm speakers in MegII doors
Postby renier » Fri May 23, 2008 10:51 am
Welcome to the forum (and groeten uit Holland :) )
There'se no room for fitting other speaker sizes than 13 cm in the front doors, without cutting away the plastic trim above the speakers as far as I know. Cutting that away will potentially cause water problems, so I wouldn't advice it. In addition to the limitation of the speaker diameter, the depth is also a problem, not all 13 cm speakers will fit.
There's a solution to fit 16 cm speakers, a German company sells custom made door parts for installing 16 cm speakers in the front doors. Looks great but expensive solution. Unfortunately, I cannot find it on the web anymore as I do not know the name. But I'me sure I've seen it on this forum as well.
I've got Pioneer TS-Q131C in the front and TS-E1396 in the back, sounds great and a perfect fit
Erik Olijnsma
Postby Erik Olijnsma » Fri May 23, 2008 11:13 am
haha thanks,
Well, I am not scared of cutting into the plastic or steel of the door. It is a lot of work, but if done properly, the internal structure will be not changed. And it is quite easy to make it waterproof once again.
The magnets on my speakers are altough a little larger, so I guess I need to check depth of speakers and the space between the doorpanel and side-window.
So, listening to your words, I guess it is not a easy fix, but it sounds not that bad either. Nice project upcoming :)
Mattj
Currently Drives:: Renault Megane 1.9 DCi
Postby Mattj » Sun May 25, 2008 9:03 am
good luck in your project - but big warning which will be repeated by lots of others on here - if you cut the standard waterproofing it seems to muck about with the standard electronics thru water ingress but ultimately your decision - have tried dynamat waterproof and few others but ended up selling the car and getting another megane as mucked up all the door electrics etc
The company for selling the 16cm door pods is https://www.mr-db.de/
Renault Megane II - 1.9 dCI
Erik Olijnsma
Postby Erik Olijnsma » Sun May 25, 2008 11:51 am
That might be enough for me not to modify...However, I dealt with more of this, so I am going to give it a look anyway.
Thanks though!
renier
Postby renier » Sun May 25, 2008 2:59 pm
That's indeed the one I ment! Looks great but expensive solution
moho
Postby moho » Tue May 27, 2008 1:04 pm
I have found this solution for 16 cm: https://www.powernetshop.at/tuerpaneele- ... rau-2.html it is also expensive.
_ivo_
Currently Drives:: Renault Megane II sedan 1,6 16v
Postby _ivo_ » Sun Jun 01, 2008 10:07 am
Hello!
Does somebody know what is the maximum depth of 13 speakers to install in front and back doors of Megane sedan?
Regards to all from Croatia...
kmarty
Postby kmarty » Mon Jun 02, 2008 8:19 pm
_ivo_ wrote:Hello!
GrandTour have same depth, I think:
So I think, 55mm is absolutelly maximum possible depth where speaker already touching glass.
MEGΛNE Expression Grand Tour/Grandtour/Estate/Tourer 1.6 automat - 2005
sorry for my poor english
Image (Image)
_ivo_
Postby _ivo_ » Tue Jun 03, 2008 6:56 am
Thanks a lot! :hug
kmarty
Postby kmarty » Tue Jun 03, 2008 7:25 am
Oh, late :-(
I forgot one important thing - this (almost) 55mm you can count only when you cut a "rain-stop", the top half of speaker holder.
(on picture is show above screwdriver):
Otherwise you will be very limited in choice of speakers due to very small place for speaker magnet.
Image (Image)
_ivo_
Postby _ivo_ » Tue Jun 03, 2008 9:15 am
kmarty wrote:Oh, late :-(
and without cuting is how much?
I'm inserting Hertz DSK130. I think they are 52mm :banghead
kmarty
Postby kmarty » Tue Jun 03, 2008 9:37 am
_ivo_ wrote:I'm inserting Hertz DSK130. I think they are 52mm :banghead
DSK130 will not fit without cutting "rain-stop" shield.
Without mods, you can place only few types of speakers (and most of them have reverse-mounted drive - in front of membrane). Like Pioneer TS-Q131C:
Image Image
Image (Image)
_ivo_
Postby _ivo_ » Tue Jun 03, 2008 10:40 am
now this is a problem :cry
but didn't you have water then later in doors ?
kmarty
Postby kmarty » Tue Jun 03, 2008 11:47 am
_ivo_ wrote:but didn't you have water then later in doors ?
Yes. But water you often have anyway, no matter if there is "rain-stop" shield or not (i had water leakage on driver-side door and it had "rain-stop" shield).
You must did something else to avoid water leakage.
P.S.: I have still "rain-stop" shields uncutted. But I speculate for another speakers and any other need mod inside the doors.
Image (Image)
Users browsing this forum: Google Adsense [Bot] and 17 guests
