timing belt change
graham dci
Currently Drives:: megane sports tourer1.9 dci privilage
timing belt change
Postby graham dci » Fri May 09, 2008 9:20 pm
is there a "how to" on timing belt changes phoned the stealers they wanted...........£403 just to change the thing im going to do it my self just want a bit info :D
Re: timing belt change
Postby wanda » Sat May 10, 2008 7:45 am
If its not its not under waranty then you can get it done for under £200 in a normal garage....
Postby AlexB » Sun May 11, 2008 1:08 am
It is described in the repair manual pointed at in Links (I should stop replying to each topic with this phrase...). I have not tried it yet, but will possibly do next autumn.
markren2004
Postby markren2004 » Mon May 12, 2008 11:28 am
The haynes manual gives is a 3 spanners difficulty (out of 5), so it's for the reasonably experienced home mechanic.
it does mention about having to make a bespoke locking tool to lock the cams whilst the belt is off.
I personally think it is one job best left to a garage.
