can anyone please tell me how i adjust them so my two little girls cant open the doors.
i looked in the owners manual and it just says move them and they wont budge is there a secial tool or something thanks.
also wen i start the car i get a little orange light appear on the dash on the left hand side it looks like an airbag with a person with a little bit of seatbelt(sorry about explanation) and the serv ice light comes on and it also sounds like the doors are locking any help on both would be appreciated t
thanks
safety locks on backdoors
Re: safety locks on backdoors
I have read something about a poor connection on the wiring under the seat that has something to do with the airbag. This is one possible source of the light on your dashboard so use the search facility to have a look through the ownership problems for related threads.
Does the switch to disable the rear electric windows also lock the rear doors?
See page 17 in the manual. It does not say "move them", I am afraid... Is it what you read?
viewtopic.php?f=10&t=6783
Bradz wrote:can anyone please tell me how i adjust them so my two little girls cant open the doors.
thanks
- WebCode
Eh? What vehicle are we talking about here?
On the Megane II and Scenic II the child locks are operated from a switch located on the driverside electric window switch panel.. Press the bottom button on the panel and the switch light will illuminate. The rear doors will be child locked and the windows cannot be operated from the rear.
regards the AirBag light...i'm wondering if this is just telling you that the passenger AirBag is switched off ???
there is a switch on the side of the dash, only visable when the drivers door is open...this is to turn-on/off the passenger airbag...maybe your's is just switched off ?
With regards to the passenger air back light, I have the same problem, keeps coming on and off willy nilly, I had the same problem with a Clio I bought and it had summit to do with the connections under the seat...I took it in and they fixed, and they said it was a common fault(if it's so common why wire it up that way in the first place
sorry it is a 52 plate megane 1.416v dynamique.my manual is different from this.
no the airbag is on i have tried that.
thanks anyway its not a major thing is it?
- robznet
Airbag + service normally indicates a problem with the airbag rotary switch (aka clockspring). I am in the process of having my second one replaced, does the steering wheel click when going from lock to lock?
Rob
Rob
no it does not i have not noticed it anyway.and i got it wrong it is an authentique not dynamique sorry.there is like a black clip not connected to anything under drivers seat is that it??
Most likely -- yes. Please be careful playing with it. Static electricity or a glitch may detonate the airbags!
- Currently Drives:: Renault Megane 1.9 DCi
if your gunna play - disconnect the battery for at least 30 mins and then clip the switch back in - just to be on the safe side
Renault Megane II - 1.9 dCI
there does not seem to be anything to clip it to and also there is like s big box hanging loose under the seat too any ideas wot that could b?
