Battery cover screws ...
pmoss
Postby pmoss » Wed Mar 26, 2008 10:35 am
Dont suppose anybody knows if the screws/attachments which hold the plastic battery cover in place can be purchased from Renault and if so, what the part number(s) would be?
I will approach the local dealer, but I can already see the stock "no - you have to buy the whole cover as a kit" answer! ;)
Cheers,
Pete
1.6 VVT Dynamique Sport Hatch 'Flame Red' on 17" Nervasports .... nice!
pmoss
Re: Battery cover screws ...
Postby pmoss » Sat Apr 05, 2008 9:45 am
well, finally got these - what a bargain, only £2.80 + VAT for a couple of screws and a little clip thing!
mind you, nothing compared to the cost of the spark plug grease which I got (based on posts on here about how it is important to protect the coils) - what a snip at £34 a tube!
cheers,
pete
onlydiesels
Postby onlydiesels » Sat Apr 05, 2008 10:11 am
pmoss wrote:well, finally got these - what a bargain, only £2.80 + VAT for a couple of screws and a little clio thing!
cheers,
pete
well you certainly seem to have an eye for a bargain :lol: . robbing b@#;ards
TheFinn
Postby TheFinn » Sat Apr 05, 2008 11:21 am
Now that would have been a bargain! ;-) Provided it had been MOT'd, of course...... :D
@ pmoss: You don't happen to have the part numbers for the above parts?
2,0 16V 6-speed manual: Image - Image
pmoss
Postby pmoss » Tue Apr 08, 2008 11:56 am
77 05 096 068 N/STOCK PIN @ £1.24
77 03 072 393 N/STOCK RIVET METAL @ £1.24
82 00 168 855 SILICONE GREASE @ £33.81 :shock:
cactusbob
Postby cactusbob » Mon Apr 14, 2008 10:01 pm
Wouldn't a tiny bit of copper grease on the threads have done the job for just a few quid?
225 5dr FF + Xenons
http://www.meganesport.net
TheFinn
Postby TheFinn » Tue Apr 15, 2008 2:26 pm
^ I think he meant grease for the coils, not the spark plug threads. The grease goes between the rubber 'boot' of the coil and the spark plug, preventing water getting in. I think it's called fluorine grease or summit like that?
BTW, copper grease is not ideal for use in aluminium cylinder heads, as it can provoke oxydisation of the aluminium... Might be better to use aluminium grease instead (costs about the same as copper grease).
kenny1001
Postby kenny1001 » Tue Apr 15, 2008 5:07 pm
Went to Renault Today to order these, got the pins from the part number but they could not recognise the below on any of the parts systems or the renault main parts listings.
Anybody know of a different part number for these?
