How to remove drivers airbag?
robznet
Currently Drives:: Megane 1.5dci
Postby robznet » Tue Mar 18, 2008 7:37 pm
Hi guys
I find myself needing to replace my airbag rotary switch, but need to find out how to remove the driver's airbag without the thing going bang! :D
Managed to find the part number on Dialogys, but my version has never allowed me to view the workshop manuals - don't know why! I have also PMd silencer51 on the subject because he has replaced many of these I believe. Does anyone have any detailed info on the subject? Any help would be greatly appreciated!!
BTW - my local stealer wont even give me a ballpark figure for the job, they want to do a diagnostic check on it first - £88.12 - and if they do the work they will deduct it from the total cost! What would that be then? I asked. I couldn't tell you, we will have to do the diagnostics first was the reply!!!! :)
Gobsmacked but any help would be great.
Regards
Rob
Deano16v
Re: How to remove drivers airbag?
Postby Deano16v » Tue Mar 18, 2008 8:29 pm
disconnect the battery and leave it for at least 30 mins mate, more to be safe. take the cover off the steering wheel, unplug the airbag and remove.
thats a rough guide anyway. just make sure the system discharges by leaving the battery disconnected for long enough
robznet
Postby robznet » Wed Mar 19, 2008 1:32 am
Cheers Deano but it looks like there is no cover on the steering wheel (on Dialogys anyway) rather that the airbag/cover is a single item and you remove it as a whole by popping a small screwdriver in a hole on the rear of the bottom portion of the wheel and slide it upwards.
Don't mean to sound ungrateful but I'm trying to avoid blowing myself to pieces, this is what Renault say about the issue -
Before removing a component from the safety system, it is essential to check the airbag computer using the Diagnostic tool.
When this function is activated all the triggering lines are disabled and the airbag warning light on the instrument panel lights up (ignition on).
Never handle the pyrotechnic systems (pretensioners
or airbags) near to a source of heat or
naked flame - they may be triggered.
Just trying to be safe! any further info greatly appreciated!
Regards
Rob
Mike_M
Postby Mike_M » Thu May 08, 2008 11:31 am
did u manage to remove the airbag as i need to replace the rotary switch too :-(
robznet
Postby robznet » Thu May 08, 2008 5:04 pm
Hi Mike - yes but didn't do it myself in the end! see below.
viewtopic.php?f=7&t=7388
Rob
villi
Postby villi » Fri May 09, 2008 10:43 am
I have sucessfully done this myself, if you follow the procedure of removing the battery for 30 mins you should be ok (i take no responsability if it goes pearsheped for somone else)
After that its fairly simple. I got my a complete rotary switch assembley from these guys for about £50 IIRC.
https://www.airbagsforsale.com/identify? ... mit=Search
All the blah about locking the airbag is just that, blah!
On my car everything reset back to normal, airbag light went out and the steering lock resumed function :cool:
Mike_M
Postby Mike_M » Fri May 09, 2008 11:21 am
thanks for the info, i picked up the assy this morning and had a little panic on the way back as it didnt have the radio control stalk on it, i am assuming that can come off the old and plugged into the new assy?
The only thing i'm still not sure on is how to get the wheel off, i've had a good sniff around the backl of the wheel but cant see anything obvious on how to remove it, is there some hidden hole somewhere??
Ta, Mike :)
Postby AlexB » Fri May 09, 2008 1:46 pm
p81 here:
https://meganedoksi.uw.hu/MEGANE_II/MR364MEGANE3.PDF
See Links for everything else.
Mike_M
Postby Mike_M » Fri May 09, 2008 2:01 pm
ah ha!
Thanks Alex! :D
Good job the other half can speak French, hehe
Will let you know how i get on.
(Daft init, I built my own turbo charged mini but cant remove the bloody steering wheel of a Renault :lol: )
Mike_M
Postby Mike_M » Sun May 11, 2008 2:00 pm
:D with the info you all provided, i did the job in just under an hour, including about 20 mins just leaving it discharging. Re-connected the battery and all works fine and the airbag and service lights went out and stayed out, woohoo!
Thanks again chaps 8) :D
robznet
Postby robznet » Sun May 11, 2008 5:40 pm
Congrats! - well done Mike. :D
Rob
Postby AlexB » Sun May 11, 2008 11:39 pm
:cool:
Mike_M
Postby Mike_M » Mon May 12, 2008 7:53 am
guess who didnt check he had a note of the radio code :roll:
robznet
Postby robznet » Mon May 12, 2008 1:33 pm
Oh bugger!!! - isn't it inside your service booklet or on a sticker inside your Renault wallet? (the big black thing with your handbook and stuff inside)
Rob
Mike_M
Postby Mike_M » Mon May 12, 2008 5:55 pm
i thought that might of been it but it didnt seem to work, but then again i might of got it wrong, i'll try again :)
