Just came back from the dealer and here is a list of the items you may find useful:
Filter Oil (77 00 274 177) £6.59
Washer (82 00 641 648) £1.24
Filter Air (82 00 371 661) £11.40
Filter Cabin (77 01 055 109) £14.47
Spark Plug x 4 (77 00 500 155) £23.54
So the total is £60+VAT for original parts I do not think is too bad.
Five litres of Mobil1 Oil 0w40 is around £45 in Halfords.
Four NGK Iridum Spark Plugs (bkr6eix) £32.70 next day delivery from sparkplugs.co.uk
I am taking the car to the main dealer, do you think they will be happy to use the plugs and oil if I buy it elsewhere?
04 Plate 1.6 Petrol Service Parts Price list (Surrey Area)
- IainMW
As long as the oil you supply meets the correct grade and spec for your engine they cannot argue.
Halfrauds are a rip off for oil. You can get oil much cheaper form other sources, (oilman on here will do you a good deal if you contact him.)
https://www.opieoils.co.uk
As for the plugs, not sure
IainMW wrote:You can get oil much cheaper form other sources
Was reading around here what the specs need to be and this Mobil 1 0w40 is "ACEA A3" so will be suitable. I did check opieoils unfortunatelly I left it too late to order online.. the car is going in for service on Monday =(
The iridium spark plugs arrived yesterday, they have been recommended here in this forum so giving them a try, I will report any issue.
