1.6 16V PRIVELEDGE AIR BAG LIGHT AND STEERING NOT LOCKED
- Currently Drives:: 07 plate 1.6 16v Automatic megane cc Privilege.
HI MY SERVICE LIGHT HAS JUST COME ON TOTALLY NORMAL IT IS DUE A SERVICE, BUT AT THE SAME TIME THE AIR BAG LIGHT CAME ON AND STAYS ON AS WELL AS STEERING NOT LOCKED IN THE MESSAGE WINDOW OF THE DASHBOARD DISPLAY. CAN ANYONE HELP IN ANY WAY ? MANY THANKS IN ADVANCE. DARREN
DAZBOY
Re: 1.6 16V PRIVELEDGE AIR BAG LIGHT AND STEERING NOT LOCKED
I've recently purchased a Megane dynamique 1.4 p, and within 3 months had problems with the coils above the spark plugs, problems with the air pressure in the accelerator or something cannot quite remember and now the same fault as you guys above. I was going to check out the fuses but had a look at the connecitons under the drivers seat and the air bag light and service light turned off.
- Currently Drives:: 2004 Megane Dynamique 1.6 VVT
Ayup,
Have you checked your battery? I'm non-technical at this sort of thing but when I was having car-starting problems, this did come up on my dash after I tried to start the car several times, I'm guessing I was eventually wearing the battery down.
Good luck,
Good luck,
- Currently Drives:: Megane II 03
Dazboy,
Did you ever rectify the problem if so how mines been gone for a while now and after searching endlessly have no ideas how to.
do you year some "clicks" when you turn your wheel? does your steering locks when you take out your card?
no not that i can hear, when I turn the engine off and take the card out it sounds and feels like it is trying to lock but it doesn't. checked the connectors under the seat by advise and using your helpful link on another topic they all seemed fine however I am missing one of the plastic rails on the passanger side would this have any affect?
Users browsing this forum: No registered users and 95 guests
