Tune point/ Audio Connection Box Installation
abul007
Postby abul007 » Wed Jan 16, 2008 10:09 pm
Is the a way of installing the tunepoint inside the glovebox without drilling any holes? or is there anywhere else it can go??
in what way is the update tuner list better than the tuner list model?
Thanks.
Megane 03, 1.6, 3 Door Silver
Gav
Re: Tune point/ Audio Connection Box Installation
Postby Gav » Thu Jan 17, 2008 12:57 pm
abul007 wrote:in what way is the update tuner list better than the tuner list model?
The update list has an aux in, so you can connect another input. The tuner list doesn't have it. Otherwise they are pretty much the same.
TheFinn
Postby TheFinn » Thu Jan 17, 2008 8:05 pm
abul007 wrote:Hi,
Thanks.
You should be able to route the cable through the aperture through which the light shines into the glovebox. (Provided the "mirrored" glovebox of RHD cars is any similar to those of the LHD cars...)
BTW, if anyone needs the mounting template for drilling the Tunepoint mounting holes, I've scanned it for download here:
https://netti.nic.fi/~gordini/archive/re ... mplate.jpg
And here's an example of how to use it... ;)
2,0 16V 6-speed manual: Image - Image
abul007
Postby abul007 » Fri Jan 18, 2008 12:18 pm
Thanks alot !!
