Window Problem...
abul007
Window Problem...
Postby abul007 » Sun Dec 30, 2007 11:37 am
Hi Guys,
Recently my passenger side window goes up and down slowly and in stages. U have to press it a few times to open/close it.
I just had a headunit fitted on with the amp wire going through the pass door side then in through the trims. Do u think dat caused any probs?
Thanks.
Megane 03, 1.6, 3 Door Silver
onlydiesels
Postby onlydiesels » Sun Dec 30, 2007 11:44 am
if the battery has been disconnected,you will have to reset the switches as follows...with both front windows fully closed,hold both switches in the `up` position for approx 10 seconds...DONE..! may be worth doing the rear switches as well.
abul007
Postby abul007 » Sun Dec 30, 2007 9:56 pm
Thanks, All sorted !!!
Users browsing this forum: Google [Bot] and 59 guests
