Radio Code required - Renault one not working :(
DciDynamique
Postby DciDynamique » Mon Dec 17, 2007 2:37 pm
Right, after the horrendous clutch ordeal, I now have a problem with the radio. Since the battery has been off it seems to have re-set itself so it now requires a 4digit code.
I've rang Renault with the VIN and Reg and they gave me a 4 digit code. Unfortunately it doesn't work :( All I get is this inane dull beep. To be honest I'm not even sure I'm entering it right; I use digits 1 - 4 of the unit to change the respective code digits, but then press button 5 to enter the code. Is this right?
If so, it appears I have a radio with no code. Is it worth me sending it off to be re-coded, or trying one of theses instant code companies online?
Many thanks
A disheartened Sean!
72uoba
Postby 72uoba » Mon Dec 17, 2007 3:05 pm
Use the remote controls next to the steering wheel. The scroll wheel changes the numbers one at a time. Press the button underneath (on the bottom) to move to the next number. Having entered the four numbers, hold this button for a few seconds and it should confirm the code.
renier
Postby renier » Mon Dec 17, 2007 7:49 pm
The process to enter the security code is also clearly explained in the owners manual... :zz
drewp
Postby drewp » Mon Dec 17, 2007 7:58 pm
my handbook also said press button 5 to enter the code but this didn't work. however,using button 6 instead seemed to do the trick for me.
DciDynamique
Postby DciDynamique » Tue Dec 18, 2007 10:33 am
That would be the owners book that we appear to be lacking.
Followed what 72uoba posted and it worked a treat. Radio now working fine. Thanks for your help :)
72uoba
Postby 72uoba » Tue Dec 18, 2007 1:20 pm
You're welcome (x4) :wink:
matauzen
Currently Drives:: megane II shake it.
Re: Radio Code required - Renault one not working :(
Postby matauzen » Thu May 23, 2013 10:05 am
hi guys,
my battery needed a change and i have a problem with my radio. cannot seem to find the code and the link to the blogsport is not working either.
does anyone have the link please?
Users browsing this forum: Google [Bot] and 78 guests
