reverse lights
monkertron
reverse lights
Postby monkertron » Fri Nov 30, 2007 9:40 am
Here's a stupid one, someone kindly pointed out i have no reverse lights at present, I'm positive i've only always noticed one reverse light on my megane, is this the case or is there two? And i've just only always had one working! Megane II 04.
Ta :o
MrAsia
Postby MrAsia » Fri Nov 30, 2007 10:20 am
There is suppose to be 2
Remapped Mégane 1.6L
Watson21
Currently Drives:: 2007/57 Megane Renault Sport 175dCi.
Postby Watson21 » Fri Nov 30, 2007 10:29 am
Yup....there are definately supposed to be two reverse lights.
Although this has triggered me to ask another question about rear lights. Are there supposed to be two fog lights on the back of the Megane??
Anyway, at least the rear lights a damn sight easier to replace than the front ones!
2007/57 Renault Sport 175 2.0dCi in Silver.
MrAsia
Postby MrAsia » Fri Nov 30, 2007 11:28 am
There is 2 rear fog lights at the back, BUT only one is wired up.
You can drag a wire from the working one and put it on the one that isn't connected.
Deano16v
Postby Deano16v » Fri Nov 30, 2007 10:32 pm
your reverse lights switch has probably gone. cheap enough to replace.
monkertron
Postby monkertron » Tue Dec 04, 2007 12:18 pm
How easy is it to replace a reverse switch? If so HOW? Thanks
cactusbob
Postby cactusbob » Tue Dec 04, 2007 12:25 pm
It should be somewhere under the gear lever I think, pull the gaiter up and have a look
225 5dr FF + Xenons
http://www.meganesport.net
Bumpy macaroon
Postby Bumpy macaroon » Tue Dec 04, 2007 8:56 pm
Was looking for this sort of info on renault forum, apparently the sensor/switch is on the gearbox itself in that dark oily area under the bonnet, it has a green connector with two wires, the connector can be tricky to remove but a quick test is to remove connectr, short out the connector and apply juice if bulbs light then get a new switch/sensor, it unscrews from the gearbox. apparently it is on the topside of the gearbox so no transmission oil will fall out, have not looked at mine yet so cant confirm but know from other car (not ren) that the sensor was there. have fun looking......
Bumpy and full of coconuts.
Users browsing this forum: No registered users and 84 guests
