Turning off ASR
Turning off ASR
i have amegane 225 2006 and for some reason the asr will reactivate automaticly after 50 km/hr is ther anyway to turn it off completly ?
Strange unless you have rally driving skills and like to splash the cash on tyres month after month I have only ever used mine on about 2 occasions and for 5 mins each time
The roads are too damp greasy dirty to not use it, matter of time until your picking you teeth one by one out of a tree at the side of the road
But best of luck with geting it sorted anyway
____________
________
____
L77
________
____
L77
Re: Turning off ASR
Liking your line of thinking Micheal.
I was goin to post a similar question myself. Mine doesnt seem to re-activate itself during driving but it does everytime you turn the engine off like renault intended. booooo.
Has the ESR tried to kill you yet? Mine has twice! Reason being i can be a touch absent minded. So if im out playing and its turned off fine. But if i stop for petrol or something ive twice forgoten to switch it off again when i start the car up.
As im sure you know the ESR has the ability to reduce power or apply brakes. Mine tends to favour the apply brakes approach! Cheers renault!
Both times ive been mid slide (car speed and approach set up to slide around corner everything going fine then about half way round the corner BANG the ESP wakes up sh1ts itself (pardon my french) and slams the brakes on. Im sorry but if the car is sliding the last thing you want to do is to stamp the brakes!!! What were renault thinking???!
At least if it cut backed on the power you'd get a touch of lift off oversteer which you could easily correct but for the car to brake that hard of its own accord when your not expecting it (as its not necessary) is dangerous and has almost caused me to spin a couple of times.
For a car marketed as a drivers car they sure got this wrong!
