Car won't start when pressing clutch pedal
The car won't start by pressing the clutch pedal and pressing the start button. I have to press the brake pedal instead. Is this a fault with the car or should I not worry and just use the brake pedal to start it?
Renault Megane 53/2003 1.6 VV Dynamique
Very common problem - well documented on here somewhere if you search. Also very simple to fix if you have any diy skills. If you look at the clutch pedal just above where your toes would be if you had you're foot on it you will see a switch with a wiring connector at the top. In your case you will probably see a broken wire just by it! You simply need to re-attch the broken wire to the connector block - if you extend it a bit with a few cm of extra wire it wont be under tension so shouldn't break again (for a while at least) unless you have size 12's and catch your foot on it!
Thanks - I will look in the day light over the weekend. Cheers!!
- Bumpy macaroon
wife had same problem
The wifes 1.4 meggy had same glitch, it was still in warrenty period and the dealer knew exactly what the problem was before i showed him the wire that had gone walkabout, so a known fault to renault....
Bumpy and full of coconuts.
Users browsing this forum: Google Adsense [Bot] and 32 guests
