TDC location?
spungal69
TDC location?
Postby spungal69 » Thu Aug 16, 2007 2:32 pm
Could anyone tell me the location of the TDC sensor
I've got that power dip at 2000rpm, hopefully can clean the sensor if I can get to it externally with a possible change, easy fix?
Jonault
Postby Jonault » Thu Aug 16, 2007 2:39 pm
It's at the top of the clutch bell housing next to the engine block. I think it is held in place by two bolts and should have some wires coming out of it. It may not be clearly visible as there may be some hoses that obscure it from view.
oldbury863
Currently Drives:: Eclipse 1.6 Dynamique (07)
Postby oldbury863 » Thu Aug 16, 2007 2:56 pm
I used my daughter's small make-up mirror & a torch to locate the sensor. Once out, remove any swarf that may be attached to the end of the sensor. Mine remains trouble free, a year after I cleaned it.
