just seen a renault megan
reg number HN03 RUY
only done 2500 miles
is a 03 model a good buy
i think its a dynamique
but dealer says its a prestige
i have heard horror storries about electrics
tested it today and there was a fault with wipers and headlites coming on for no reason is this normal
can it be solved
is anyone registered with my renault can they check the reg for recalls
NEW BUYER
- navid.v
Wezhoy,if you check with RAC or sites like that it comes up as 2003 megane 1.6 Dynamique.
as Basenji mentioned,the 2003 models have had loads of problems,that might explain the very low milleage,you better consider the later model for your own peace of mind.
- IainMW
As the others say go for a newer model if you can afford it? Early Megane's can be rather problematic, but it just depends on the individual car?
Megane's have auto lights and wipers, which can cause problems. Any Renault dealer will be able to tell what recalls and remedial work needs to be done to the car.
I'd have a hunt around because there are some very good deals on newer models. If there was a fault with any car when I took it for a test drive I'd dismiss it straight away.
ive decided to go for it
6 month warrenty will clear any faults
should be ok !!
ive seen loads of 03's on the road
here is to my new megane !!!
lol Hope its not a lemon !!
what you mean when you say depands on the individual car ?
what are the odds on a 03 being a bad one 20% or more or less ?? Hmmm ?
should be ok !!
1.6VVT Ottoman Dynamique 03' Plate with Comfort Pack & Sat Nav
"Take It Easy!"
"Take It Easy!"
- IainMW
Congratulations on you're purchase. Hope it serves you well.
What I mean is that some cars suffer more faults than others? So you could have an 03 plate that has been totally faulty free, and another that has been plagued with one fault after another. If you've bought it from a Renault dealer, they will be able to give you a print out of all the warranty/recall work that has been carried out on the car.
Enjoy your new car
Enjoy your new car
- navid.v
another good way of knowing what recalls left on your car,is to register with MY RENAULT section on renault.co.uk,when you enter the car details it will notify you of any remaining recalls (if there is any).
hopefully everything goes fine
mechanicaly the car is purfect,
radio and sat nav needs replacing no sound and wont accept cds !!!
cd changer needs replacing !!!
Love the car already
both jobs above getting done by garage ! under buyers warrenty !!
unless anyone knows a fix
"Take It Easy!"
"Take It Easy!"
