Drive shaft nut's (removal)
nico
Postby nico » Thu Aug 02, 2007 9:54 pm
Hi every body,
I'm in the process of removing my broken engine, i came to undo the drive shaft nuts and they will not budge.
Does any body know an easy way of undoing them ?
Or is it possible to remove the block with the gearbox still mounted.
03 Megane 1.5 dci owner.
Husky_Dog
Postby Husky_Dog » Fri Aug 03, 2007 12:22 pm
Use a longer breaker bar!! 8)
These nuts are always really tight, and you will need to replace them when you come to put the shafts back again.
Good luck - think Gorrilla Power! :D :D
2005 Scenic 1.9Dci 120 Exception
