SERVICE light ON!!! One of many problems!!
mark_b
Postby mark_b » Sat Jul 28, 2007 12:48 am
service light jus came on the night for the 1st time...and it came up on the dash, electronic fault!!! any ideas??
next minor problems are as follows:- 1. Cracked door handle
2. Squeaky Brakes
3. Sunroof rattles
4. 1st gear seems a bit jumpy! although this problem could be caused by me! :(
my car is an 04 Dynamique which has covered 32,000miles! only got the car 2 weeks ago...n these problems are bugging me!! i got a years warranty with it! Will the 1st 3 faults b covered by this??
thanks mark...
markren2004
Postby markren2004 » Mon Jul 30, 2007 7:25 am
if youve only had it 2 weeks the first thing to do is take it back to where you bought it from.
If it's an 04 with 1yr warranty I guess the warranty with the car is an after market one and not with renault ?
is the car under 3yrs old ?, if so you might have better luck under the 3yr manufacturer warranty at a main dealer.
Apart from the "electronic fault" these are all common problems, and probably not covered by your warranty (wear & tear), and you'll probably be charged for Diagnosis, including pluging in the computer to see what the electonic fault is.
