Plastic Scratched
bronkone7
Currently Drives:: 2004 Renault Megane 1600cc
Plastic Scratched
Postby bronkone7 » Mon Jul 02, 2007 2:48 pm
Hi all
I've recently purchased a Megane 53 1600 16v.
The interior plastic down the post between front and rear door is quite deeply scratched,was when i bought it,can it be replaced?if so does it just unclip or do you need special tool.
Many Thanks
Brian
TheFinn
Postby TheFinn » Mon Jul 02, 2007 3:23 pm
Should unclip easily: Pull the top of the panel outwards to unclip the top, then lift up to release the bottom of the panel.
It's available separately, but there are different colors available hence different part numbers. You'll find the interior trim colour code printed on a sticker down the B-pillar when you open the rh front door: it should be either HARM01 or HARM02.
HARM01 lh side: 8200165362
HARM01 rh side: 8200165366
HARM02 lh side: 8200165372
HARM02 rh side: 8200165373
Those part numbers are from 2002, don't know if Renault has changed the numbers since (something they do every now and then...)
bronkone7
Plastic Scratched
Postby bronkone7 » Mon Jul 02, 2007 9:43 pm
Smashing, thanks very much.
Will check it out tomorrow.
Brian
bronkone7
Plastic Scratched
Postby bronkone7 » Wed Jul 04, 2007 3:08 pm
Have ordered new bit..should get Friday....£22.50
Thanks for your help.
Brian :D
