Outside air temp gauge reading low. Where is it?
spungal69
Postby spungal69 » Thu Jun 28, 2007 2:38 pm
Air temp gauge reading about 10 deg to low.
Anybody Know where the sensor is located?
Megane 1.6 dynamique
Flame red
03 plate
48000m
Hoody
Postby Hoody » Thu Jun 28, 2007 2:40 pm
Yeah it is normally under the wing mirrors. It looks like a little black rain drop.
Nick
Megane II 1.5 Dci Dynamique 3dr, Ottoman Blue, Private Registration, Sony GT30RN Head Unit, ShinyAutos.com Interior White LED Kit, 3rd Brake Light Cover, MOC Sticker
spungal69
Postby spungal69 » Thu Jun 28, 2007 3:20 pm
I will have a go at looking it.
Presumably pop the cover off the mirror? Both?
Postby AlexB » Fri Jun 29, 2007 12:15 am
It's on the right side.
spungal69
Postby spungal69 » Fri Jun 29, 2007 5:27 pm
Sorted!!!
Right hand mirror cover off pulled out checked the wiring and cleaned, Satis
Thanks for the help
Mick
Outside temp sensor
Postby Mick » Wed Oct 03, 2007 1:57 pm
Hi there, my 04 meg has just started UNDEREADING outside temp by 10 degrees, how do you get the drivers wing mirror cover off without damage so that I can clean or replace the thermister ? :roll:
spungal69
Outside air temp sensor-cover off
Postby spungal69 » Thu Oct 04, 2007 9:33 pm
In order to get the cover off you need to prise the coloured part off the right handside mirror. I used a steel ruler starting at the outside edge working it along about halfway, the fold the mirror inwards to finally remove the cover.
If you use a screwdriver you may damage the cover unless you cover the edges with masking tape this may help.
The temp probe is a sealed unit with two grey wires leading out of it, you cannot clean it with anything I think the method replacement would be buy cutting the wires and re-joining them with the new probe or a used one from a scrapyard far, far cheaper.
Hope this helps
Mick
Postby Mick » Sun Oct 07, 2007 9:51 am
Thanks for your guidance, I didnt need to change the sensor but found that the connector pins between the door and the car body needed a clean. Job sorted. :cool:
Rorry
Currently Drives:: Renault Megane Sedane 1.5dci 2003
Re: Outside air temp gauge reading low. Where is it?
Postby Rorry » Mon May 04, 2009 12:32 pm
My display (the one with the clock) stopped showing outside temp.
I Know Renault service mess this up, either when they cleaned my A/C or when they replaced right front door electric window mechanism.
Is there a way to fix this problem? Probably some wires are disconnected.
My name is Renault Megane Sedan 1.5dCi manufactured 2004 A.D.
